Crower
Old Sep 14, 2001 | 11:29 PM
96b18c's Avatar
Default Crower
I have a set of 402A cams, valve springs, retainers, and cam gears and also plan on getting a muge head gasket and was wondering if the V-AFC would be substantial or should I get a diferent ECU. If so is the skunk2 one good?This is all on a 96 GS-R. Any sugestions will be appreciated.
Old Sep 15, 2001 | 12:35 PM
Eeepers's Avatar
New User
Default Re: Crower (96b18c)
Get the v-afc or a field s-afc, an B&M FPR, and head off to the dyno. And since you are pulling the head off, get the mugen headgasket, it will bump compression up 0.4 and it doesn't cost much more than the stock gasket. ECU programming is not really necessary.
What you want to do is make sure you're not running lean. At the dyno, they should have a wideband o2 sensor there so you can monitor your air/fuel ratio.
Old Sep 15, 2001 | 07:49 PM
96b18c's Avatar
thanks
Old Sep 15, 2001 | 07:57 PM
96b18c's Avatar
I was also wondering were my redline should be at and if I should get my rev limiter removed?
Mattb16teg
Jun 10, 2005 09:00 AM
kell211
Dec 12, 2004 05:05 PM
Crackerballer
Dec 30, 2003 01:04 AM
Teal95Coupe
Mar 21, 2003 10:52 PM
JdoggsGSR
Apr 28, 2002 01:13 PM
