Which one are you perfer??
Old Jun 8, 2005 | 09:24 PM
Edward's Avatar
Default Which one are you perfer??
The above one have better kw.
The below one have better torque.
Which one is better?? Better kw or better torque??
Old Jun 8, 2005 | 09:40 PM
B2FiNiTY's Avatar
Default Re: Which one are you perfer?? (Edward)
Looks like top one has more power AND More tq?
Old Jun 8, 2005 | 10:06 PM
mugenracer's Avatar
what are we looking at? 143kw = 192bhp. 115kw = 154bhp...thats a huge difference in anyones book. Are they both of the same car with different exhausts/manifolds or what??????
Old Jun 8, 2005 | 10:13 PM
Grin-T's Avatar
One's a Type R and the other is not?
Old Jun 8, 2005 | 10:28 PM
nightrider's Avatar
the increased amount of toque will not make up for the huge loss in hp.
Old Jun 8, 2005 | 11:18 PM
itr1244's Avatar
i go with 143.7
Old Jun 9, 2005 | 03:45 AM
Edward's Avatar
Default Re: Which one are you perfer?? (B2FiNiTY)
There are different dyno and same car.
They had different cam gear setting. Don't concentrate on the kw. Different dyno got different number. Who care?
Just compare the torque, i think the below one is better.
Old Jun 9, 2005 | 04:49 AM
dax-es's Avatar
So what are you saying? That they shouldn't be compared, yet the second graph is the better of the two? From what can be seen, the first graph is done in fourth and the second in third gear, on a different dyno and presumably on "5th Jan 1999". Further, you have already made up your mind regarding this issue as well; your preference for the second. I guess the question I'm asking is whether or not I'm missing something?
Old Jun 9, 2005 | 05:21 AM
Dr Pooface's Avatar
Default Re: Which one are you perfer?? (dax-es)
I believe he is saying to not compare the #'s (because you can't with different dynos), but to look at the shape of the torque curve. You can see the top one is flatter, while the one on the bottom seems to rise before it drops off at the end.
Only way to tell for sure is to do a base line run, then make whatever changes you want and run it again immediatly. Comparing runs that are made on different dynos is difficult. One could argue that maybe the peak tq of the bottom graph is the same as the top one, therefore the bottom graph is a weaker run.
Old Jun 9, 2005 | 05:24 AM
Bbasso's Avatar
Do I spy a AEM CAI on that chart?
But I would prefer a nice flat TQ curve... Btw which is what I have now, and feels Great!
Old Jun 9, 2005 | 05:40 AM
Chris F's Avatar
Default Re: Which one are you perfer?? (Bbasso)
If you guys look at the scale, the bottom one has more torque. ~3200 newton-meters (I figure) versus 3800 N-M
You can make up for torque with gearing, however you can't make up horsepower.
ITR wins! If I had to guess, are we looking at an ITR versus a tuned LS motor?
Old Jun 9, 2005 | 07:13 AM
nsxtasy's Avatar
H-T Order of Merit
I thought dyno plots usually use RPM as the X axis, not road speed.
The first plot says it was done in fourth gear. The second plot doesn't say, but given that it only goes up to 79 miles per hour, I'm guessing that it's in third gear and has shorter gearing than the stock USM gearing, which goes up to 89 mph in third.
Very confusing...
Old Jun 9, 2005 | 07:19 AM
Chris F's Avatar
Default Re: Which one are you perfer?? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Whoops. Yeah Ken, they use RPM when there's a good RPM signal going to the dyno computer. If not, or they don't hook it up, then all you can graph is the speed of the dyno wheel.
Being unfamiliar with the units I just assumed "N" was "Nm", measured somewhere. Not the flywheel, if it doesn't have a RPM pickup.
Old Jun 9, 2005 | 07:29 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">I thought dyno plots usually use RPM as the X axis, not road speed.</TD></TR></TABLE>
I actually had to convince the owner of the last shop I worked at that rpm was better on the X axis than road speed. In fact Dynojets (I don't know about others) can't even measure torque without having the Engine Speed Sensor hooked up.
Phoenix1
Aug 29, 2005 08:47 PM
typhoon
Feb 10, 2005 11:38 AM
TommyV
Honda S2000
Feb 24, 2004 10:44 AM
RangerDan
Feb 8, 2003 01:41 AM
l
Mar 26, 2002 06:18 PM
