mpfi question???
Old Jun 8, 2005 | 08:12 PM
boosted_hatch_216's Avatar
Default mpfi question???
my problem is that my car will not start. itll start for about a half second and die right out, and my check engine light and a couple other lights stay on when i take the key out of the ignition. so mainly what i am getting from wat ive searched is that its probably the ground or not enough of them. is this true? can anyone think of anyother reason why the car would do this? its not throwing any codes and ive checked everytbit of wiring like ten times over. thanks for the help in advance.
Old Jun 8, 2005 | 10:02 PM
Default Re: mpfi question??? (boosted_hatch_216)
bump cause someones gotta have an idea...........
Old Jun 8, 2005 | 10:38 PM
som1_2race's Avatar
What exactly was done>DPFI to MPFI?
Old Jun 8, 2005 | 10:48 PM
Default Re: (som1_2race)
yeah
Old Jun 9, 2005 | 12:15 AM
NikoZai's Avatar
Default Re: (boosted_hatch_216)
ummmmm
- First check for continuity on the injector wiring.
A1 pin to #1 injector .. and so on. (A3 A5 A7)
You're using a PM6 ecu right?
- Check continuity on the Distributor wiring.
Injector resistor box wired correctly?
(its not a ground... its a 12v+ converting to 5.5v+ going to the injectors.)
These are the common mistakes. Investigate, if you don't know how to use a volt meter, you need to learn to use one. Don't ask here, search google, or read the manual that came with the volt meter.
Good Luck!
Old Jun 9, 2005 | 05:44 AM
crx90rcr's Avatar
Default Re: (NikoZai)
check your ignition timeing u may have the distibutor on 180 deg. off i did this and it ran but sometimes shot flames out the intake then turned off
Old Jun 9, 2005 | 06:16 AM
86si's Avatar
ignition switch
Old Jun 9, 2005 | 09:46 PM
crx90rcr's Avatar
Default Re: mpfi question??? (86si)
yea like a month or 2 after i had my mpfi swap running my dist rotor was loose so it would sometimes cut out like a min after i started it or like on the high way as im driven
apekd
Jan 15, 2009 04:57 PM
RxglassJAw
Jun 16, 2008 06:33 AM
ef9king
Feb 16, 2006 12:03 AM
sepulchralx
Sep 16, 2005 06:34 AM
revtech motorsports
Mar 22, 2005 03:03 PM
