What cams for my motor? ...can't decide
head...
99 p72
-ported
-3 angle
-Crower valvetrain
-ITR valves
-milled .030
block...
JDM GSR
-stock
-with the mill i'm expecting an 11.4:1 CR
i was going to just run the ITR cams and call it a day, but this guy really inspired me stock JDM GSR bottom end, unported head, Blox cams...running a 13.2 (click me). Because of this i've decided to just keep running my stock head for a while as i save for some better cams, then sell the ITR's
i understand how cams work, with lift and duration etc, but i don't really know a lot about specific cams, (i've been searching a lot.) What cams would you all mota guru's recomend? Should i just copy this guy and use the Blox cams?
thanks in advance
all motor = the most gangsta
99 p72
-ported
-3 angle
-Crower valvetrain
-ITR valves
-milled .030
block...
JDM GSR
-stock
thanks in advance
Blox cams works great and good price, or if you want you can spend more like me use JUN type 3 cams. No matter what cams you use make sure upgrade your valve springs and retainers as well as a set of cam gears....good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 »</TD></TR><TR><TD CLASS="quote">Blox cams works great and good price, or if you want you can spend more like me use JUN type 3 cams. No matter what cams you use make sure upgrade your valve springs and retainers as well as a set of cam gears....good luck</TD></TR></TABLE>
did you read my post?
realis9
May 20, 2007 03:11 PM
realis9
May 20, 2007 12:15 PM
