New Thermostat
Old Jun 8, 2005 | 07:00 PM
wbw3434's Avatar
Default New Thermostat
Hey! One quick question. I just replaced the thermostat in my 1997 DX hatchback, and the check engine light came on and now it won't go off. What's up with that? Help anyone??
Thanks in advance,
WBW3
Old Jun 8, 2005 | 07:06 PM
neutron91's Avatar
Default Re: New Thermostat (wbw3434)
did you plug the coolant temp sensor back in... if im thinking correctly the sensor is on the thermostat housing on your car
Old Jun 8, 2005 | 07:13 PM
solareclipseauto's Avatar
Default Re: New Thermostat (neutron91)
check the sensor
Old Jun 8, 2005 | 07:17 PM
wbw3434's Avatar
Default Re: New Thermostat (solareclipseauto)
Actually, I never removed the sensor to get the housing off. Should I unplug the sensor and plug back in, or just replace sensor?
Old Jun 8, 2005 | 07:18 PM
JBG's Ferio's Avatar
Maybe you should jump the ecu and get the cel code, that would help answer your question...
Old Jun 9, 2005 | 08:22 PM
blackeg's Avatar
Default Re: New Thermostat (JBG's Ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBG’s Ferio &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you should jump the ecu and get the cel code, that would help answer your question...</TD></TR></TABLE>
corkss
Nov 3, 2008 10:44 AM
BrokenHatch
12
May 31, 2005 05:26 PM
D3U1LT
Nov 11, 2004 11:34 PM
lilxvtecxpwr
Aug 15, 2002 11:27 AM
