Transmission pulling out of gear
Old Jun 8, 2005 | 06:32 PM
90AcuraIntegra04's Avatar
Default Transmission pulling out of gear
Okay i was driving my car, it would pop itself out of 5th and i realize that my clutch engages when the pedal is almost all the way up. When i adjust the clutch cable, would i turn the adjuster, would i turn it clockwise or counterclockwise in order for it to engage more in the middle.
Old Jun 8, 2005 | 06:42 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: Transmission pulling out of gear (90AcuraIntegra04)
just adjust it and then get in the car and push the pedal. if you cant feel it that way then drive it. it should only take about 10 minutes to readjust it.
Old Jun 8, 2005 | 08:07 PM
Gant's Avatar
would it pop itself outta 5th when u let go of the gas?
Old Jun 8, 2005 | 08:13 PM
DA6Iceman's Avatar
with a cable clutch you should have about a half of an inch in slop in the pedal so when you adjust it you should be able to move the pedal with your hand.. you want to turn the adjuster clockwise if your lookin at it from the top. hope that helps
Old Jun 8, 2005 | 08:16 PM
vizions's Avatar
when my car had bad syncros it use to pop out of gear by itself.
Old Jun 8, 2005 | 10:54 PM
oldtegskoo90's Avatar
Default Re: (vizions)
my car gears use to pop out of gear, man dont listen to what some other person say. you are low in transmission fluid, just double check the level of fluid in it and refill, you could use motor oil 2
Old Jun 8, 2005 | 10:57 PM
90LSpimpin's Avatar
Default Re: (oldtegskoo90)
Yea, its a lot cheaper and quicker to just refill the trans fluid than to just assume the synchros are bad and replace the trans. Turn the adjuster clockwise to raise the engagement point, and counter-clockwise to put it closer to the floor.
zapzach
Apr 15, 2013 12:30 PM
Alchemist Dragon
Classic Hondas
Jul 18, 2010 04:00 PM
DANINE101
Transmission & Drivetrain
Mar 13, 2010 10:04 AM
dumada9
Jan 23, 2010 03:27 AM
[626]95-GSR
Feb 15, 2002 02:52 AM
