allignment all f**ed up
Old Feb 9, 2002 | 09:12 PM
hondur guru's Avatar
New User
Default allignment all f**ed up
ok, so my allignment is all messed up lately. The problem is that my car pulls to the right massivly on the freeway. It also has a reall bad jitter at about 60+. There is nothin really odd with my front allignment. The camber is about -1 and -.3. I do though have .53" of toe in on my right rear wheel due to a slightly bent trailing arm. I'm not sure if that right toe would m,ake it pull to the right that badly though. I would think it would make it pull to the left if anything. Does anyone have any idea on what might be the problem? What normally makes cars pull badly to one side of the other?
BTW: its a 95 civic coupe dropped on tokico illuminas and neuspeed race springs.
Old Feb 10, 2002 | 10:03 AM
New User
Default Re: allignment all f**ed up (hondur guru)
noone has any ideas???????
Old Feb 10, 2002 | 03:20 PM
Jared's Avatar
try setting your tire pressures evenly and swapping your front tires side to side and see if that changes the pull. also, the rear being out would cause it to pull as well since the rear will tend to "steer" the car.
Old Feb 10, 2002 | 05:42 PM
1 2 NV's Avatar
jareds right, swap the tires on the front, sometimes the pull can come from a tire, if it pulls to the opposite side when the tires r swapped, its the tire. the vibration at 60+ is from unbalanced tires. go get them balanced and itll b ok.
CFF
Suspension & Brakes
Dec 27, 2009 02:27 PM
GSRkrod
Honda S2000
17
Oct 13, 2009 05:15 PM
yOnKiNaToR
Oct 16, 2008 06:39 PM
cstoltie
Aug 25, 2002 02:46 PM
cstoltie
Aug 24, 2002 11:09 PM
