Is the car getting pushed backwards while in gear bad?
Old Jun 8, 2005 | 03:49 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Is the car getting pushed backwards while in gear bad?
My driveway is a big *** hill and I always park with the car in first gear and the e-brake all the way up. My dumb *** brother was parked in front of me and thought his pathfinder was in drive, well it wasn't and he nailed the gas. His tow hitch smashed my bumper and sent my car rolling backwards.
Luckily it rolled slow enough so that when it hit the road my brother was able to stop it before it went off the cliff and into my neighbors house.
So basically I'm just wondering how the hell a transmission works and if anything might be fucked up? I always thought that if the car was off and it was in gear it couldn't roll backwards.
I'm assuming that it was just the clutch giving way and slipping or something?
Fill me in here on what the hell happened
Old Jun 8, 2005 | 04:03 PM
jdmGSR.fo0!'s Avatar
Default Re: Is the car getting pushed backwards while in gear bad? (RebornGSR)
Damn.. That sucks.. Does the car drive ok? If everything works fine I doubt taht thee is anything messed up with it. Most likely just popped out of gear.
Old Jun 8, 2005 | 04:20 PM
whiteJDMdc2's Avatar
what happens when you park your car when in gear is that the motors compression helps it from rolling backwards... it is still possable to move a car when in gear.. its kinda like when you put a wrench on the crank pully and try to turn it its hard to turn it but you can still turn it... same concept... no there should be nothing wrong with your car motor wise but im guessing your bumper is messed up
creation25
Nov 30, 2012 07:25 AM
mnskateboarder
Transmission & Drivetrain
11
Oct 25, 2009 08:01 PM
boostedeghatch
14
Jan 14, 2009 11:11 AM
WeaponR
May 25, 2004 04:14 PM
paybac4223
Oct 28, 2002 03:01 PM
