Car goes pisssssht at idle??
Old Jun 8, 2005 | 03:00 PM
GoCart's Avatar
Default Car goes pisssssht at idle??
Sounds like pressure is being released. Idle seems to stutter after noise. Seem to happen after longer periods of idle. Appears to be random.
Old Jun 8, 2005 | 03:05 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Car goes pisssssht at idle?? (GoCart)
I'm going to go out on a limb here.............you have a short ram intake, dont you?
Old Jun 8, 2005 | 03:08 PM
simplegreenmachine's Avatar
Default Re: Car goes pisssssht at idle?? (jlacoy82)
vaccum leak? or some sort of leak?
Old Jun 8, 2005 | 03:09 PM
GoCart's Avatar
Nope. AEM Cold Air
Old Jun 8, 2005 | 03:39 PM
jlacoy82's Avatar
71.192.16.183
A/C turned on?
Is it the cooling fan kicking on because you have it sitting there idling?
Old Jun 8, 2005 | 03:48 PM
funvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">A/C turned on?
Is it the cooling fan kicking on because you have it sitting there idling?</TD></TR></TABLE>
thats what i was thinking
Old Jun 8, 2005 | 04:10 PM
civiccpedx's Avatar
im guessing it is your intake
Old Jun 8, 2005 | 04:49 PM
SleepnCiViC's Avatar
lot of hondas w/ intake make that noise, double check for a vacume leak though
Old Jun 8, 2005 | 04:50 PM
CRacer21's Avatar
That's what I was thinking.
Old Jun 8, 2005 | 04:52 PM
blacksihatch's Avatar
Default Re: Car goes pisssssht at idle?? (CRacer21)
No NO NOOOOO Flat tire ...DUH!!!!!
funvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funvtec &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i was thinking </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRacer21 &raquo;</TD></TR><TR><TD CLASS="quote">
That's what I was thinking. </TD></TR></TABLE>
hey ****** don't bite mystyle
lol
Old Jun 8, 2005 | 09:38 PM
GoCart's Avatar
Default Re: Car goes pisssssht at idle?? (funvtec)
Does it with A/C off. Fan is rigged, always on. Where should I look for a vacuum leak. Thanks for the responses!
Old Jun 9, 2005 | 06:32 AM
GoCart's Avatar
ttt
Old Jun 9, 2005 | 07:41 AM
CRacer21's Avatar
lol </TD></TR></TABLE>
Mine's better, see the smiley and I capitalized the 'That's'.
Old Jun 9, 2005 | 07:43 AM
IHateJDM's Avatar
is your pcv valve recirculated to the IM properly?
Old Jun 9, 2005 | 08:28 AM
GoCart's Avatar
Default Re: Car goes pisssssht at idle?? (IHateJDM)
Stupid Question Alert: How do I check the PCV. The PCV ha been replaced months ago.I think I got cheap one from Pep Boys.
Old Jun 9, 2005 | 09:05 AM
mwieczorek43's Avatar
My CRX sounded like darth-vader when I had my AEM cai on it. When I shut it off, it used to "woosh" as-well.
People would ask me all the time, what was under there b/c it was so noisy. Ended up selling it.
Dont know if that helps, but dont rule-out the intake noise b/c it isn't a short-ram.
Old Jun 9, 2005 | 09:10 AM
chinkest_raver's Avatar
might be ur manifold. or just let someone drive your car around for a bit, and you stand outside to listen maybe that might help out more.
Old Jun 9, 2005 | 10:09 AM
O16581724 5 2 5's Avatar
My car does that too, but it's when i rev and release the throttle.
It does sound like a vacuum leak since it's having problems idling, go over your vacuum lines with WD40, a propane torch (not lit of course!), brake cleaner, etc. Your idle will raise when the leak is found.
chickenwing
Sep 25, 2008 02:23 AM
07siftw
Honda Civic (2006 - 2015)
23
Feb 23, 2008 05:59 PM
fin781
12
May 22, 2007 01:59 PM
Jesterian
11
Feb 22, 2006 11:56 AM
batzcivic
36
Apr 6, 2005 01:27 PM
