Can YOU Identify these cam gears?
Old Jun 8, 2005 | 02:56 PM
JDMisGOOD's Avatar
Default Can YOU Identify these cam gears?
Modified by JDMisGOOD at 9:31 PM 3/16/2006
Old Jun 8, 2005 | 03:00 PM
MikeySpec's Avatar
Default Re: Can YOU Identify these cam gears? (JDMisGOOD)
JUN?
Old Jun 8, 2005 | 05:59 PM
JDMisGOOD's Avatar
Default Re: Can YOU Identify these cam gears? (MikeySpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">JUN?</TD></TR></TABLE>
Thats what i was thinking... but i would like to know for sure...for all i know they could be some cheap knock-off...
Old Jun 8, 2005 | 06:01 PM
PirateMcFred's Avatar
Honestly they look like OEM fabbed up to be adjustable. Someone had time but no money. Does not look horrible but a bead blast and a fresh coat of paint could not hurt.
Pirate
Old Jun 8, 2005 | 06:03 PM
machine4321's Avatar
i tihkn the juns are just that ...modified stock gears
Old Jun 8, 2005 | 06:20 PM
slomofo's Avatar
GDD Member
All stock dohc cam gears i've seen have triangle cutouts in them, but my d-series look like those.
Old Jun 8, 2005 | 07:10 PM
GeezerCoupe's Avatar
I believe they are Old school JG cam gears
Old Jun 8, 2005 | 07:49 PM
MikeySpec's Avatar
Default Re: Can YOU Identify these cam gears? (GeezerCoupe)
Those are JUN cam gears. Just old and dirty. The theory behind JUN's modified stock gears was for perfect fitment. Back when those first came out....JG had theirs which were cnc cut/machined and aem had their tru-slip gears. The JG's were ok until the belt tension wore into the cam gear and made it loose teeth, and the aem's would slip all day. Jun's were the ichiban choice.
Old Jun 8, 2005 | 08:24 PM
Fobtions's Avatar
they look like they are jun's. but i remember there were a couple copycats back in the day.
i once had a set of jun's and they looked like those above.
Old Jun 8, 2005 | 08:50 PM
juntuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">Those are JUN cam gears. Just old and dirty. The theory behind JUN's modified stock gears was for perfect fitment. Back when those first came out....JG had theirs which were cnc cut/machined and aem had their tru-slip gears. The JG's were ok until the belt tension wore into the cam gear and made it loose teeth, and the aem's would slip all day. Jun's were the ichiban choice. </TD></TR></TABLE>
those ARE NOT JUN
http://www.jhpusa.com/catalog/...f241e
Old Jun 8, 2005 | 11:26 PM
MikeySpec's Avatar
Default Re: Can YOU Identify these cam gears? (juntuned)
My old ones have those rivets in the center........
Old Jun 8, 2005 | 11:39 PM
JUN-DA6's Avatar
those are for sure JUN cam gears. I have those same gears came with my JUN motors from Japan...
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juntuned &raquo;</TD></TR><TR><TD CLASS="quote">
those ARE NOT JUN
http://www.jhpusa.com/catalog/...f241e</TD></TR></TABLE>
they are all talking about the older ones.
Old Jun 9, 2005 | 03:36 AM
Davep's Avatar
I have a set of those laying around rusting someplace, they're the original style JUN gears.
blk crx
Oct 28, 2009 08:34 PM
Musmaro13
Mar 31, 2007 05:59 PM
Baggy Spandex
Jan 4, 2006 03:58 PM
junya16
Apr 21, 2003 10:04 PM
