Exahust rattling at 2700-3000 rpms
I recently installed a Comptech cat-back and the buzzing start..I had a GReddy EVO II and i had no problems with it..What could cause this rattle? I have the stock header and cat...TIA.
Same problem here, never happened at first then just progressively got worse. it "buzzes" at 2100, then stops then again at 3100 then stops. Only at those 2 points...
I checked to see if maybe it was rubbing against anything...nope
Checked to see if maybe the bolts were loose...nope
It is definitely rattling against something. My suggestion is to buy some exhaust tunnel sheilding from DEI (thermal stuff) and put it anywhere that the exhaust comes close to frame/car. This way it wont rattle.
The stuff is self adhesive on one side and it can withstand heat up to like 1700F.
I used this where my exhaust rattles and now it doesn't. I also used it on the underside of my hood cause my full race mani was starting to ruin my paint.
one quick question..when i installed the new Comptech cat-back i did not have the gasket that goes right after the cat...the one that is triangular...could that be causing the exahust leek/rattle? do i need it?
ya, its a good idea to have it cuz then the pipes wont rust together as fast..i think. and its shouldnt cause teh rattling if they are tightly bolted together, but just like jack up the car and have a friend rav it, and try to pin point where teh rattling is coming from. Also, are u running a silencer?
it could also be a bad set up...not to diss or anything but it could be rattling against your rear bumper or control arms or even body....same thing happened to me. make sure the exhaust doesnt have the ability to touch the car...
IT is possible that the heat from the cat is warming up the heatshield above it, attached to the car and the heatshield itself is rattling cause its flimsy metal.
Try letting the car warm up and as others said, rev it up a few times and get the rattle to happen. Then pinpoint where it is.
I'm willing to be it is a heatshield itself getting warm and rattling, but only after the car warms up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">Check the connection between the header collector and the exhaust or cat.</TD></TR></TABLE> The gasket would help.
I am also having a similar rattling sound at around 3500rpm right after I installed my apexi ws2 catback. I pretty much pinpointed the sound to be the heat shield around the cat which I tried to take off but had no luck. The reason I knew it was the heat shield is because when the car was cooled down I banged on it and it made a rattling sound. I might need some airtools to get those rusted bolts off but the sound isn't as bad when it's hot.
i had a terrible buzzing noise coming from either the cat or resonator for the longest time. the buzzing slowly moved to the muffler and then one day it just quit. well it didn't quit, it just greatly quieted down. i took my center console out (to check the broken factory radio stuffed in my dash for keyless entry) and you can still hear the buzzing coming from either the resonator or cat, but it's just a faint buzzing now. really wierd. i've replaced the resonator, next is the cat. oh, and i'm definitely gonna do the thermal wrap.
