THIS IS THE FRONT JACKING POINT & other stuff
Old Feb 9, 2002 | 07:30 PM
GRM Scott's Avatar
25 Year Member
Default THIS IS THE FRONT JACKING POINT & other stuff
No one can ask where it is agian. If they do, kill them, and then show them this. It's in the my tools section on S&M racing. I've also added some other random stuff, most notably AEM rear pads, also put in some ATE Super Blue.
Old Feb 9, 2002 | 07:33 PM
ceas's Avatar
Default Re: THIS IS THE FRONT JACKING POINT & other stuff (Aleph)
Yes- and dont look for it in the middle on civics.. Honda wisely put it offset to the left hand side, meaning that when the driver side is just high enough to fit your jackstand under, the passenger side usually needs to go up another 5 inches. Go, Honda, Go!
ceas..
Old Feb 9, 2002 | 07:42 PM
MrBite's Avatar
...yours may not have quite so much salt on it and for those with older 'tegs, you have to cut/hack/dremel off a piece of the splash guard so it doesn't slip off the jack. Ask me how I know...
Old Feb 9, 2002 | 08:20 PM
Wildohiorice's Avatar
New User
Default Re: THIS IS THE FRONT JACKING POINT & other stuff (MrBite)
looks like u have the same rubbing problems lol, i see u have scrapped a few times.
Old Feb 9, 2002 | 10:02 PM
GRM Scott's Avatar
25 Year Member
Default Re: THIS IS THE FRONT JACKING POINT & other stuff (Wildohiorice)
i have a really steep driveway entrance, the car has stock rally height, so it never scrapes on the street....that jacking point is bitched up from being used so much
Old Feb 9, 2002 | 10:03 PM
Yellow Dragon's Avatar
Can't you just use the front tow hooks?
Old Feb 9, 2002 | 10:15 PM
GRM Scott's Avatar
25 Year Member
Default Re: THIS IS THE FRONT JACKING POINT & other stuff (Yellow Dragon)
of course you can. But then you make the jacking point feel unloved. There's so many questions about this, i figured i'd take a pic while i had it up.
Old Feb 9, 2002 | 10:16 PM
thanks for the info. I always seem to learn new things here...even simple things like jack points.
Old Feb 10, 2002 | 01:36 AM
GZR4DR's Avatar
I use the tow hooks always, you can raise the car up higher. But yes, that is the proper jacking point.
Old Feb 10, 2002 | 08:11 AM
coquinn's Avatar
Default Re: THIS IS THE FRONT JACKING POINT & other stuff (GZR4DR)
Really sucks when those tow hooks bend on you though.
[Modified by coquinn, 12:11 PM 2/10/2002]
Old Feb 10, 2002 | 09:07 AM
Floyd's Avatar
Default Re: THIS IS THE FRONT JACKING POINT & other stuff (73rd 2000 ITR)
After using the front jack point to raise the nose up, I put two jack stands under the side jack points right behind the front wheels. Then I move to the back of the car and use the rear tie-town hook to jack the rear, and put two jackstands under the side jack points right in front of the rear wheels. In order to do this right, your jack has to have a decent lifting height, especially for the rear.
Didn't someone even do a write-up on their website on how to jack the car up and put it on jack stands? It's been a while, though.
Old Feb 10, 2002 | 09:09 AM
MrBite's Avatar
Did you even look at the site??
Old Feb 10, 2002 | 10:25 AM
GRM Scott's Avatar
25 Year Member
Default Re: THIS IS THE FRONT JACKING POINT & other stuff (Floyd)
S&M Racing: If we don't have the answer to your question, you shouldn't be asking it
Old Feb 10, 2002 | 12:25 PM
Tommy_Gunns's Avatar
Anybody remove all that plastic weather guard stuff from their cars? I was thinking of doing it.
Johnny Mayday
Honda-Tech News
14
Feb 8, 2017 05:41 AM
1slowcrx
Paint and Body
Sep 13, 2008 09:34 PM
davidqwerty
Aug 17, 2004 12:33 PM
krshultz
Nov 19, 2001 03:55 PM
