Why Hondata?
Old Jun 8, 2005 | 09:45 AM
UserX826's Avatar
Default Why Hondata?
What exactly do engine managment systems such as hondata do? Why does this help when boosting?
Old Jun 8, 2005 | 10:08 AM
Relic1's Avatar
I'm positive this has been covered before... but
Boost on a car not designed for it will die very quickly without some sort of fuel increasing device.
And since the stock ECU does not have any special fuel/ignition maps to run while under boost, Hondata/Uberdata/Chrome create such maps to handle everything correctly.
http://www.hondata.com/aboutus.html
Old Jun 8, 2005 | 10:19 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Relic1)
Basically, a Hondata, or any engine management system, gives you the ability to change the stock ECU settings to further benefit the modifications you have done to your motor already. Its basically like getting your ECU chipped, only the changes aren't static, you can modify them based on power gains or losses, fuel economy and etc.. if you have a built motor, its definatly a good investment.
Hondata however, is still a "piggyback" system. It uses your stock ECU so you get a good idle, and modifies it.
JDM B16A
Mar 24, 2006 10:41 AM
hitvtecgetloud09
Nov 14, 2005 05:56 AM
imonx850
Jan 5, 2005 09:19 PM
ZColeon
Mar 8, 2002 01:09 PM
b16sipsssh
Nov 24, 2001 09:03 AM
