hondata
Old Nov 23, 2001 | 01:11 PM
b16sipsssh's Avatar
New User
Default hondata
alright this is definetely a stupid question........... what exactly is hondata?? im very new with the FI setup and don't know too much about everything still. i also wanted to know what i needed to get in order to hit 12's??
[Modified by b16sipsssh, 10:12 PM 11/23/2001]
Old Nov 23, 2001 | 01:28 PM
internet ay's Avatar
Default Re: hondata (b16sipsssh)
hondata is a standalone engine management. basically it replaces y0ur stock computer and makes it so that you can control fuel ,spark,boost and such on a labtop with windows software and hondata also has datalogging. you dont need a hondata system to hit 12's but you will need some type of fuel controler .
Old Nov 23, 2001 | 05:00 PM
MackSpeed-616's Avatar
Default Re: hondata (internet ay)
that description is rather far from the truth. it does not replace your stock ecu, but rather works in conjuction with your stock ecu and allows the implication of modified fuel and ignition maps. Hondata's dont control boost either. you will need a boost controller for that.
Old Nov 23, 2001 | 08:23 PM
Liltrix's Avatar
Default Re: hondata (TurboR616)
Actually, its a reprogrammed stock ecu, Most restrictions are either removed or modified to accept and run boost. It also give U the ability to fine tune car's performance
Old Nov 24, 2001 | 09:03 AM
im sorry i was just giving information the way i perceived it from hondatas website. i should of said instead of replacing the ecu you send it to them and they modify it making it programmable. in hondatas websites words"Hondata modifies standard Honda ECUs, adding features and expanding the capabilities of the ECU (to read boost for example)". i thought that the b meant that it controls boost , i guess it just reads it instead of fooling it with check valves. i guess i was wrong.
[Modified by internet ay, 6:06 PM 11/24/2001]
[Modified by internet ay, 6:07 PM 11/24/2001]
[Modified by internet ay, 6:14 PM 11/24/2001]
JDM B16A
Mar 24, 2006 10:41 AM
hitvtecgetloud09
Nov 14, 2005 05:56 AM
4gZC
Sep 9, 2005 05:27 PM
UserX826
Jun 8, 2005 10:19 AM
evo75
Jun 17, 2002 04:46 AM
