car runs sluggish when hot
Old Jun 8, 2005 | 03:31 AM
94delsol's Avatar
Default car runs sluggish when hot
my car runs fine when i first start it up untill it gets really hot... just installed new MSD ignition and compression check is 215 215 190 215 and leak down ran 4. when it gets hot the car climbs RPMS pretty slowly and you can sorta feel it cut out a little bit but not too much to hear it...but anyone got any ideas where to start checking? car also gets pretty hot standing still and you have to turn heater on for the car to cool down also ... i dont know if that conflicts with my sluggish or not..anyways thanks
Old Jun 8, 2005 | 10:25 AM
Sam92Teg's Avatar
Default Re: car runs sluggish when hot (94delsol)
Yes an overheating car will hurt performance, fix the overheating issue. And I hope you are not like your avitar, a lazy jackass. j/k
Old Jun 8, 2005 | 12:41 PM
therealpoorboy's Avatar
sounds like you have a blown headgasket.
Old Jun 8, 2005 | 02:03 PM
HondaIntegraR's Avatar
Default Re: car runs sluggish when hot (therealpoorboy)
maybe your detonating?
Old Jun 11, 2005 | 02:43 AM
327da9's Avatar
Did you check your thermostat, or maybe the cooling system wasnt bleed properly the last time you filled ur radiator w/ coolant.
What kinda setup are you running, maybe its time for a bigger radiator
I hate summer and all the heat related car problems that come with it
Rlcky
Honda Civic (2001 - 2005)
Aug 10, 2016 06:24 AM
slow2002gt
Jun 25, 2011 11:47 AM
ctr32
Aug 10, 2009 03:03 PM
jeremyrocksursox
Jul 15, 2009 05:58 AM
AMChev
Sep 26, 2002 10:08 AM
