Increasing Compression by skimming the head on b16a2????
Old Jun 8, 2005 | 01:58 AM
supaman111's Avatar
Default Increasing Compression by skimming the head on b16a2????
Hi i am about to install Sir2 cams in my car as i want some extra power without increasing revs and keeping honda oem parts, i understand that the compression is higher on the sir2 compared to the non jdm b16, would skimmin the head be safe? and how much do i get it skimmed, i want it to be safe and get a flywheel hp gain of about 10hp at least with the cams
sam
Old Jun 8, 2005 | 04:34 AM
dwnthehatch's Avatar
Default Re: Increasing Compression by skimming the head on b16a2???? (supaman111)
Just get a 1 or 2 layer headgasket. It's cheaper and won't have to worry about ruining your head.
Old Jun 8, 2005 | 06:19 AM
supaman111's Avatar
Default Re: Increasing Compression by skimming the head on b16a2???? (dwnthehatch)
would a mugen head gasket do??
Old Jun 8, 2005 | 07:19 AM
. o 69 o .'s Avatar
so you are replacing b16 cams in a b16 motor with another set of b16 cams? uhhhh....
Old Jun 9, 2005 | 12:04 AM
supaman111's Avatar
Default Re: Increasing Compression by skimming the head on b16a2???? (B16B)
yeh got a non jdm b16a2 158 hp, and replacing cams with sir2 ones 167hp which i got for £35 which is about $60, i was told the compression is slightly higher on sir2 so i will install a thinner head gasket or skim the head to get the full 10-12 hp gain. I am only doing this as my Head Gasket needs replacing anyways.
Need ideas on how much to mill head or what head gasket to go for?? I dont like installing thing that are not really oem honda unless mugen or spoon. I also dont really want to raise rev limit as i will have to mess with ecu.
sam
Old Jun 9, 2005 | 06:28 AM
. o 69 o .'s Avatar
pistons raise compression, not cams.
Old Jun 10, 2005 | 12:52 AM
supaman111's Avatar
i understand this, the sir2 cams and the apparantley higher cr from the pistons on ther jdm motor get the extra 9hp, i want about 12hp from installing the sir2 cams and a mugen gasket on a non jdm b16. I dont want to go into bottom end
is this likely?
Old Jun 10, 2005 | 01:08 AM
JDMOrangeFever's Avatar
What you are trying to say is if you put the headgasket and 2nd gen cams in you will increase your horsepower to a stock JDM 2nd gen b16? That would prob work yeah.. depends on layer of head gasket if its 1 layer it will prob be a little higher.. US 10.2-1... jdm 10.4-1. Prob about a 10 hp change.. Yeah go for it why not? I swapped my 2nd gen cams with my brothers 1st gen jdm and made good difference.. not insane just a we amount.
Old Jun 10, 2005 | 01:36 AM
EG6R's Avatar
I understand you. Im sorry it doesnt work like that. The difference will be too little that you wont even feel it. If your not done yet with the basic I/H/E just do that instead.
Old Jun 10, 2005 | 03:06 AM
supaman111's Avatar
Default Re: Increasing Compression by skimming the head on b16a2???? (EG6R)
Sir2 engine works much better with jap 98 Octane Fuel and you can see a clear difference from a non jdm b16. I have already done I/H/E managed 178hp with 98 Octane hoping for 185hp with 98 Octane. Should make a good difference over 80mph+, i understand its not going to make me quicker off the lights
sam
preluking
Oct 19, 2008 04:36 PM
dragonfly2k3
10
Jan 22, 2008 09:51 PM
all-mtr-teg
15
Nov 30, 2006 08:43 PM
99RedSi
12
Mar 10, 2005 10:34 AM
Unsung
May 25, 2002 12:19 PM
