Need Help!!!!!!!!!!!!!!!!!!
Old Jun 8, 2005 | 12:02 AM
k_spec's Avatar
Default Need Help!!!!!!!!!!!!!!!!!!
I dont know what seems to be the problem on my B16.
everytime its gonna hit the VTEC and i have my foot on the accelerator all the way, its like its bugging. (i dont know if that's the right word) but it loose power. like its engine braking. i dunno. normal driving is fine. the power is ok for a b16 stock as long as i dont step on it full throttle.
need help!!!!!!!!!!!!!!1
Old Jun 8, 2005 | 12:22 AM
JINX'D's Avatar
Default Re: Need Help!!!!!!!!!!!!!!!!!! (k_spec)
check your timing and spark.
I had a similar if not same problem with my second gen B16. it would be pulling fine until about 1,000 rpm before VTEC, then the power would flat line, as if i let off the throttle a bit, thenVTEC engaged and continued pulling to redline.
i changed, dizzy cap and rotor, fuel filter, played with different grades of fuel, spark plugs, then i finally checked my timing, it was so advanced it was off the chart... brang it back to TDC, and she ran perfect, even faster!!, BTW: i find Mid grade fuel to be the best for the B16.
Old Jun 9, 2005 | 09:00 PM
k_spec's Avatar
Default Re: Need Help!!!!!!!!!!!!!!!!!! (JINX'D)
i did wat u said. the timing and all that but still the same. got any more idea?
honda_del_sol
Dec 6, 2010 01:40 PM
GABOCRX
10
Aug 9, 2009 08:47 PM
ef9rida
Mar 31, 2009 09:59 AM
DOHCRX
May 13, 2003 01:50 PM
Griffins_Importuning
Jul 16, 2002 07:00 PM
