Suspension & Brakes Theory, alignment, spring rates....
suspension specialist... need a little help
Old Jun 7, 2005 | 11:52 PM
david
Guest
Posts: n/a
Default suspension specialist... need a little help
a set of h&r race springs (98 civic) for my 94 del sol. now i need a set of shocks/struts.
i've read bottoming out, bump stops, hacking, etc... because of the rates and drop of those springs, what set of shocks/struts can i just toss on my car (plug and play) that i wouldn't have to worry about any problems at all. i'm a simple person. i just want them not to blow or malfunction in any way. ride quality, handling, performance issues i care little of. i appreciate it.
Old Jun 8, 2005 | 06:15 AM
Solracer's Avatar
Default Re: suspension specialist... need a little help (david)
Just and FYI you have shocks on your car.... but depends on what you do.
Tockico Illuminas are good street shock
KYB AGX are good street shock
Koni Reds are a better street/perfomance shock
Koni Yellows are best. Street/track/perfomance
Old Jun 8, 2005 | 06:16 AM
krnfly2damoon's Avatar
KoNi Yellow fosho!, i think you can also use tokiko illumina
Old Jun 8, 2005 | 07:42 AM
david
Guest
Posts: n/a
so i do not have to purchase koni yellows? i've read that's the only shock that's adjustable as in (with a perches).
Old Jun 8, 2005 | 09:03 AM
Solracer's Avatar
Default Re: (david)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david &raquo;</TD></TR><TR><TD CLASS="quote">so i do not have to purchase koni yellows? i've read that's the only shock that's adjustable as in (with a perches).</TD></TR></TABLE>]
Depends on what you are looking for. Yellows are the only shock I lised that has a heigh adjustment.
Old Jun 8, 2005 | 09:23 AM
david
Guest
Posts: n/a
Default Re: (Solracer)
people tell me since the springs i have are so low and the rates are so high... i can't use anything but the yellows... every other shock i run will just blow because of this.
taimysho0
Suspension & Brakes
Aug 18, 2008 11:45 AM
taimysho0
Aug 17, 2008 06:43 PM
crazyguy
Aug 30, 2007 06:12 AM
redDAinteg
Oct 14, 2005 08:10 PM
khoa
May 15, 2002 07:49 AM
