quick terminal question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david »</TD></TR><TR><TD CLASS="quote">went to autozone today... looking for a female (subwoofer) connector. no copper terminals? the copper ones conduct electricity better no? or can i just buy regular steel ones?</TD></TR></TABLE>Not sure what you mean by "female subwoofer connector", if you mean the term. that plugs into the term. on the speaker itself, [250 female quick release, or 250 fully insulated quick release] used on most subs, then just get the "steel" ones, if you want a better connection, solder the speaker wire to the term., it's the best way to do it. P 94
YOU NEVER SOLDER WIRE TO A SPEAKER.YOU WILL AUTOMATICLY VOID THE WARRENTY ON YOUR SUBWOOFER.JUST GO TO A LOCAL STEREO SHOP AND GET THE COPPER ONESIF THEY ARE WHAT YOU WANT .YOU MAY HAVE TO GO TO 2 OR 3 SHOPS,BUT ONE HAS TO HAVE THEM.BUT YOU WILL NOT HEAR ANY DIFFERENCE IN SOUND IF YOU USE THE STEEL ONES. GOOD LUCK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">YOU NEVER SOLDER WIRE TO A SPEAKER.YOU WILL AUTOMATICLY VOID THE WARRENTY ON YOUR SUBWOOFER.JUST GO TO A LOCAL STEREO SHOP AND GET THE COPPER ONESIF THEY ARE WHAT YOU WANT .YOU MAY HAVE TO GO TO 2 OR 3 SHOPS,BUT ONE HAS TO HAVE THEM.BUT YOU WILL NOT HEAR ANY DIFFERENCE IN SOUND IF YOU USE THE STEEL ONES. GOOD LUCK</TD></TR></TABLE>What? We solder the speaker wire to all sub-woofers that do not have "cinch" term. and to all speakers when we run aftermarket speaker wire, and in over 30 years of installing I have never had a speaker co. void warranty because the speaker wires were soldered on, not once.
94
94
WELL THAT IS GOOD FOR YOU.YOU ARE THE FIRST DEALER TO SAY THAT.BUT THEN AGAIN LIKE I SAID MOST ,NOT ALL,MOST MANUFACURER WOULD NOT COVER THE WARRENTY
Torridcivic
Audio / Security / Video
Oct 17, 2003 08:31 AM
