quick terminal question
Old Jun 7, 2005 | 11:02 PM
david
Guest
Posts: n/a
Default quick terminal question
went to autozone today... looking for a female (subwoofer) connector. no copper terminals? the copper ones conduct electricity better no? or can i just buy regular steel ones?
Old Jun 8, 2005 | 11:31 AM
fcm's Avatar
fcm
Old Fart
Default Re: quick terminal question (david)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david &raquo;</TD></TR><TR><TD CLASS="quote">went to autozone today... looking for a female (subwoofer) connector. no copper terminals? the copper ones conduct electricity better no? or can i just buy regular steel ones?</TD></TR></TABLE>Not sure what you mean by "female subwoofer connector", if you mean the term. that plugs into the term. on the speaker itself, [250 female quick release, or 250 fully insulated quick release] used on most subs, then just get the "steel" ones, if you want a better connection, solder the speaker wire to the term., it's the best way to do it. P 94
Old Jun 11, 2005 | 04:52 AM
SCIVIC94's Avatar
YOU NEVER SOLDER WIRE TO A SPEAKER.YOU WILL AUTOMATICLY VOID THE WARRENTY ON YOUR SUBWOOFER.JUST GO TO A LOCAL STEREO SHOP AND GET THE COPPER ONESIF THEY ARE WHAT YOU WANT .YOU MAY HAVE TO GO TO 2 OR 3 SHOPS,BUT ONE HAS TO HAVE THEM.BUT YOU WILL NOT HEAR ANY DIFFERENCE IN SOUND IF YOU USE THE STEEL ONES. GOOD LUCK
Old Jun 11, 2005 | 10:24 AM
fcm's Avatar
fcm
Old Fart
Default Re: quick terminal question (SCIVIC94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 &raquo;</TD></TR><TR><TD CLASS="quote">YOU NEVER SOLDER WIRE TO A SPEAKER.YOU WILL AUTOMATICLY VOID THE WARRENTY ON YOUR SUBWOOFER.JUST GO TO A LOCAL STEREO SHOP AND GET THE COPPER ONESIF THEY ARE WHAT YOU WANT .YOU MAY HAVE TO GO TO 2 OR 3 SHOPS,BUT ONE HAS TO HAVE THEM.BUT YOU WILL NOT HEAR ANY DIFFERENCE IN SOUND IF YOU USE THE STEEL ONES. GOOD LUCK</TD></TR></TABLE>What? We solder the speaker wire to all sub-woofers that do not have "cinch" term. and to all speakers when we run aftermarket speaker wire, and in over 30 years of installing I have never had a speaker co. void warranty because the speaker wires were soldered on, not once. 94
Old Jun 11, 2005 | 03:36 PM
SCIVIC94's Avatar
Default Re: quick terminal question (fcm)
WELL THAT IS GOOD FOR YOU.YOU ARE THE FIRST DEALER TO SAY THAT.BUT THEN AGAIN LIKE I SAID MOST ,NOT ALL,MOST MANUFACURER WOULD NOT COVER THE WARRENTY
Old Jun 11, 2005 | 06:30 PM
will's Avatar
Just get the steel ones. Youre not going to notice a difference.
colsanders
Audio / Security / Video
Nov 15, 2007 07:47 PM
jli18
15
Jan 26, 2006 06:39 PM
89hbcivicguy
Oct 27, 2004 10:27 AM
Torridcivic
Oct 17, 2003 08:31 AM
