Tryin' to figure some things out....
I have a JDM B16A Engine and i was wondering what type of clutch do I used for it sence its a cable clutch? And, I would also like to know what year or model honda do i get my timing belt for my JDM B16A?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">94 dohc del sol..or 99-00 civic si for the timing belt....clutches are the same</TD></TR></TABLE>
Timing belt is correct but you will need a 90-91 integra clutch if the trans is a Y1, J1, S1. If the trans is a YS1 (92-93 cable trans) you will need a 92+ b series clutch assembly. The difference between the 90-91 and 92+ b series transmissions is the spline size on the input shaft. The 92+ transmissions have a larger input shaft.
ThaEfSwap
Jan 8, 2012 04:37 PM
91 HONDAsaurus rex
Mar 30, 2005 07:22 AM
ericb16hf
11
Sep 29, 2003 06:50 PM
