Water Pump leaking... Again.
Old Jun 7, 2005 | 07:44 PM
ZedEx's Avatar
Default Water Pump leaking... Again.
1994 Civic EX D16Z6
Early in March my Water Pump was leaking so bad that I just kept some 50/50 Anti-Freeze/Water in my car, and fill up the radiator every day.
So the March 6th Auto Cross was quickly approaching, and I wasn't going to run the car like that, and seeming as I didn't have the time to do it that week, I put it in a reputable shop, and had them do the maintenance... I typically do my own work, but it was March 3rd, and I was in a pinch.
Everything has been great up until the past two days... I noticed the puddles on the driveway again
Could the Water Pump seals have gone bad in that short amount of time? I haven't done that many Race Events lately... 3 Auto Cross Events once a month, and 1 run down the Drag Strip.
Is this normal? Or do I need to go down to the shop and have a word?
Thanks in advance,
Old Jun 7, 2005 | 07:48 PM
Aphelion's Avatar
Default Re: Water Pump leaking... Again. (ZedEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZedEx &raquo;</TD></TR><TR><TD CLASS="quote">Is this normal? Or do I need to go down to the shop and have a word?</TD></TR></TABLE>
I replaced mine at 90k when I did the timing belt. You don't need anyone to back you up to know that what happened to you isn't normal o_O
Old Jun 7, 2005 | 07:49 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Water Pump leaking... Again. (Aphelion)
Are you sure its the water pump, and maybe not a loose hose/clamp? Or even a hole in a coolant hose for that matter, or a coolant neck thats leaking?
Old Jun 7, 2005 | 07:56 PM
ZedEx's Avatar
Well when I got up under it, and in the engine bay, I couldn't find anything that would promote a loose hose, or any coolant line broken.
And last time that happened... It turned out to be my Water Pump seal
I'm probably going to get it up on some jack stands tomarrow and have a closer look. But damn it just doesn't seem right, it's been less than 3,000miles
Anyone else have any ideas here?
Old Jun 7, 2005 | 08:05 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (ZedEx)
Hondabond- lots of it.
Old Jun 7, 2005 | 08:12 PM
ZedEx's Avatar
... What the Hell is Hondabond?
Old Jun 7, 2005 | 08:46 PM
Morning Call's Avatar
who knows what hondabond is..
it is however possible that your pump is fucked again.. your hg could be blown causing a very high pressure in your coolant lines.. (i think its normally like 5 or 10psi).. so when your hg goes usually ur leaking pressure into the coolant.. so something thats designed for 10psi or so thats getting lets say 50 isnt gonna hold out very long
when my hg went my rad split, and my pump went..
Old Jun 7, 2005 | 08:48 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (Morning Call)
Hondabond is just a high-temp RTV silicone sealant sold with a Honda name on it.
Yeah, is there a relief hole on Honda pumps like on some other cars? I had the pump go in my old Sunfire once, and there was a relief hole where all the water leaked out when the pump died.
W95civicEXcoupe
Apr 27, 2015 04:33 AM
tundra2000
Dec 18, 2010 07:12 PM
Champs32
Feb 13, 2009 11:32 AM
IVI
Nov 20, 2004 09:22 AM
tominos
Sep 10, 2004 08:38 PM
