dashlight brightness control unit
Old Jun 7, 2005 | 07:43 PM
HmgLauj69's Avatar
Default dashlight brightness control unit
how likely is it for the control unit to cause my cluster to not to light up, does anyone know how test it. also i cant seem to find it. i believe for the 90-91 it's not in the dimmer like the 88-89. i searched and couldn't find much. i tried a few things before thinking it might be the control unit (i.e switching cluster, checking fuses, dimmer trick) any help would be
Old Jun 7, 2005 | 07:52 PM
Suck my DX's Avatar
Default Re: dashlight brightness control unit (HmgLauj69)
when my old ej got jacked they took the dimmer switch....when i got it back the cluster never lit up....i dont know much about electrical yet but i know that the signal must go through the dimmer switch before it goes to the cluster and dash...if the dimmer has gone bad you can either just replace it or bypass it
Old Jun 7, 2005 | 07:57 PM
HmgLauj69's Avatar
Default Re: dashlight brightness control unit (Suck my DX)
i tried to by pass it and doesn't work, that's why im thinking it's the control unit instead of the dimmer. the horizontal dimmers do not have the control unit inside, there's another unit (dashlight brightness control unit )
Old Jun 7, 2005 | 08:02 PM
Suck my DX's Avatar
well it seems to me like u answered ur own question
Old Jun 7, 2005 | 08:08 PM
HmgLauj69's Avatar
still trying to find answer for the questions, in case first post wasn't clear.
how likely is it for the control unit to cause my cluster to not to light up? does anyone know how test it?
Modified by HmgLauj69 at 9:29 PM 6/7/2005
Old Jun 7, 2005 | 10:27 PM
Eggman's Avatar
what year is your cluster? 88-89 is different from 90-91.
i went from 88-89 to 90-91 and had a problem with the wiring. if you have a 88-89, check out my last post here, https://honda-tech.com/zerothread?id=318615 (the cheese ball way to override it). hope that helps a bit.
Old Jun 8, 2005 | 10:48 AM
HmgLauj69's Avatar
Default Re: dashlight brightness control unit (Eggman)
my car is a 91, and it's a 91 cluster. do you by chance have a helms?
Ruthlessef9
Sep 14, 2010 10:30 AM
ek9=]
Jan 21, 2009 11:02 PM
thechamp2633
14
Dec 25, 2007 08:26 PM
zoniebutt
Sep 27, 2007 01:27 AM
TYPEROLLER#420
Jun 7, 2004 08:32 PM
