which 4-1 fits ef ?
i own a 91 hatch with a b16...but it seems that my 4-2-1 already has two MEAN dents in it and sits super close to my radiator...and the space between the radiator and block is not much...so who makes a good 4-1 header that will clear...thanks
do not get the jdm 4-1 that thing will be super low.
the only good clearance on a ef is the 4-2-1 style. spark racign loks like it will be pretty good clearance wise. since it doesnt stick out farther than the oil pan.
clearance shouldnt be that much of a problem...my car is not slammed...what did u guys ues to notch in the crossmember...i dont want a jdm itr anyways...
before getting the z-10 crossmember i had to notch the factory one just use a grinder and take a little bit out until proper clearence if i was going to recomend a header for the money it would definitly be a smsp or a hytec my opinion only though
goodluck
goodluck
theres a crazy lookin header on this board (cant remember the name-someone help me out) that fits the ef without mods. and if price isnt a factor, im sure the big name guys (RMF, SMSP, hytech, yadi yadi ya.....) can make you one. what kind of setup you runnin?
if ur talkin about the an-r compact..thats the one im currently interested in...unless i can find something better to fit with no modification thats the one i plan on getting...
my set up is:
1st gen. b16/y1
3 inch short ram
max bore 64 to 62 mm
aebs IM
str fuel rail
b&m fpr
full supertech valvetrain
aem cam gears
sk2s2 cams
dc 4-2-1
si catback
vafc
91 DX hatch
DX is for deluxe
my set up is:
1st gen. b16/y1
3 inch short ram
aebs IM
str fuel rail
b&m fpr
aem cam gears
sk2s2 cams
dc 4-2-1
si catback
vafc
91 DX hatch
DX is for deluxe
i paid 530 shipped, but i didnt get it coated, now its rusting pretty good. i dont have another header to compare it to, but its pretty nice though, good power, but the bottom pipe didnt line up too good. i had to have a muffler shop bend it-plus it didnt come with a flange.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1266654</TD></TR></TABLE>
u realize that i asked for a 4-1 header for an ef...not a 4-2-1 for an eg...
does anybody read anymore
Do you mean clear the crossmember or gound ? If your worried about the cross member, all I can say is your probably gonna have to cut it.
Anyway you look at it, if you want a nice header that is gonna perform well, your gonna have to cut the crossmember. Check out an-r
yeah the an-r compact is the one im probably gonna get...i was just seeing what else is out there....doesnt the compact fit in the ef without notching the crossmember
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">yeah the an-r compact is the one im probably gonna get...i was just seeing what else is out there....doesnt the compact fit in the ef without notching the crossmember</TD></TR></TABLE>
Not sure, ask in the all motor forum maybe.
I did read but u were complaining about clearance & alot of 4-1's have no ground clearance & will not really clear the cross member without cutting! FYI that header does not only fit an eg!!! does a dc just fit a del sol NO!
so
for u. I could have been a dick & just told u to search but I was trying to help because the spark header had already been tested on a B16
Modified by Hamstr323 at 2:48 PM 6/11/2005
</TD></TR></TABLE>I did read but u were complaining about clearance & alot of 4-1's have no ground clearance & will not really clear the cross member without cutting! FYI that header does not only fit an eg!!! does a dc just fit a del sol NO!
so
so
Modified by Hamstr323 at 2:48 PM 6/11/2005</TD></TR></TABLE>
ok...so does a welldesigned 4-2-1 work btter for street/track than a 4-1??
so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard »</TD></TR><TR><TD CLASS="quote">I believe that the Hookups header is designed for EF.
https://honda-tech.com/zerothread?id=1174760
yeah, thats the header i was talkin about....supposedly fits in a EF with no modification.
well if it is well designed yes it will perform better not all 4-1 are the same & not all 4-2-1 are the same look at what the spark header made over the kamikaze
kamikaze 4-1 vs spark 4-2-1 made 21 hp more
erick's racing 4-1 vs spark 4-2-1 made 10 hp more
im not really tryin to remove my front mount....it looks like im either gonna go with the sparks or an-r compact...does anyone know if the sparks will fit with a full radiator on an ef???
