Crank and bearings
Old Jun 7, 2005 | 05:32 PM
hondacrxhf_3's Avatar
Default Crank and bearings
I posted something on here about a month ago saying that i appearently had a loose rod in my engine. Well i guess you people said that its my bearings and my crank may have scoring. What does that mean, how do i replace them, is there a cheaper crank than 750, and do i even have to replace the crank if there is scoring? Thanks and please help me.
Old Jun 7, 2005 | 05:44 PM
turbo_smallblockchevy's Avatar
http://auto.howstuffworks.com/engine.htm imagine what happens when something comes loose
and bring your engine to a machine shop
Modified by turbo_smallblockchevy at 7:05 PM 6/7/2005
Old Jun 7, 2005 | 05:57 PM
Default Re: (turbo_smallblockchevy)
What?
Old Jun 7, 2005 | 06:08 PM
Default Re: (hondacrxhf_3)
ok i assume you had a loose rod or a spun rod bearing. usual symptom would be a fairly loud knocking noise from the lower half of the motor. depending on the severity of the case you either need a new motor or a rebuild
if you insist on trying to do this the cheapest way possible grinding the crank and polishing it along with new bearings may PATCH the problem
Old Jun 7, 2005 | 06:33 PM
ok thank you but how and where would i do that
DanishR
Oct 7, 2007 07:41 PM
ls19integra95
Feb 20, 2007 03:42 PM
hondaeg8
May 1, 2005 12:15 AM
hatchedzex
Oct 4, 2004 11:40 AM
91hatchcivic
May 9, 2004 08:49 AM
