What should I do after this compression test
Just did a compression test on my car from left to right Im at 90 80 120 120 I know theese numbers are bad so whats the first steps into fixing it the car has 75000 miles on it. And the funny thing is I dont really beat on it at all. Herlp me out Honda-Tech.
check your head for heat warpage, start with something simple.. if thats not it, then check out your pistons and rings.. more than likely, if its not your head or headgasket, its your rings.
but im no professional on this sorta thing so dont hold me to it..
start saving up money and hope that you have enough to buy another longblock after that engine dies
. it could be the headgasket though. change your oil; if its a weird diarrhea color then its your HG.
ok after I did the compression test the right way. Thanks to Honda-Tech and C-Speed Racing. Im at 200+ 200+ 200+ 200+ The dial on my compression tester is blurry. This should be ok right.
SilkyJohnson
13
Feb 15, 2011 05:54 PM
