Endyne PCV breather system experience
Old Jun 7, 2005 | 02:36 PM
Big Phat R's Avatar
Default Endyne PCV breather system experience
I just did a track day at Pacific Raceways with the Porsche Club NW last Saturday.
This spring, I installed the Endyne PCV breather system in the effort to reduce oil consumption at the track (I was typically using about 2 liters of oil every track day). I also knew that I was seriously taxing the stock system since my car is so modified.
Seen here: http://www.theoldone.com/components/breather/
One major thing I notice now with my car is the top end is way more lively - especially in 4th and 5th gear. My car just pulls and pulls even in 5th.
I am now entering Turn 1 at 140mph - which is something I've never been able to do before....it is quite scary to say the least - considering you have to stay on the gas through that turn unless you want lift throttle oversteer.
Oil consumption is down to 1 liter and I don't have a black rear bumper any more. I also noticed my fuel consumption is down too (?)
Amazing....
I highly recommend it for anyone using aftermarket cams and high compression.
Modified by Big Phat R at 6:17 PM 6/7/2005
Old Jun 7, 2005 | 02:42 PM
white rocket's Avatar
Default Re: Endyne PCV breather system experience (Big Phat R)
Good write-up. I was looking at that unit a month or so ago. I think you just sealed the deal for me. Thanx
Old Jun 7, 2005 | 02:56 PM
{Powered by VIII}'s Avatar
Default Re: Endyne PCV breather system experience (white rocket)
how much is this setup and where did you get it from?
Old Jun 7, 2005 | 03:01 PM
Willard's Avatar
Anyone with a stock motored ITR use this unit?
Old Jun 7, 2005 | 03:02 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">Good write-up. I was looking at that unit a month or so ago. I think you just sealed the deal for me. Thanx </TD></TR></TABLE>
This is my next mod too. We should team up and see if Garage 5 will give us a deal.
Old Jun 7, 2005 | 03:33 PM
Default Re: Endyne PCV breather system experience (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">Anyone with a stock motored ITR use this unit?</TD></TR></TABLE>
also would like to know this as well!
Old Jun 7, 2005 | 03:37 PM
Big Phat R's Avatar
Default Re: Endyne PCV breather system experience ({Powered by R})
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Powered by R} &raquo;</TD></TR><TR><TD CLASS="quote">how much is this setup and where did you get it from?</TD></TR></TABLE>
I bought mine locally - but they just ordered it direct from Endyne
Cost is $164.00
You can probably make it yourself from the Moroso parts and buying the hoses separately.
The catchcan does require fabbing up some sort of mounting bracket as well - as you can see in my engine bay it was positioned close to the battery.
The nice part about this catchcan system is that is re-routes the oil back to the motor.
Old Jun 7, 2005 | 04:09 PM
Default Re: Endyne PCV breather system experience (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">
This is my next mod too. We should team up and see if Garage 5 will give us a deal. </TD></TR></TABLE>
For sure. They hook it up for me pretty good @ G5. I bill all my vehicle mods through my company since it's a company car and they give me wholesale deals. Let me know and I can do it through all through my company
Old Jun 7, 2005 | 04:26 PM
Mythias's Avatar
Nice writeup. Ironic timing since I just ordered that, along with the kamikaze header.
Old Jun 7, 2005 | 04:44 PM
RaVAGE00's Avatar
New User
Default Re: Endyne PCV breather system experience (mythias)
I would be interested as well....
Old Jun 7, 2005 | 04:47 PM
Bbasso's Avatar
Dammit,,, Something else to spend money on.
How about a GB on this so maybe a few of us could save $ ???
Old Jun 7, 2005 | 05:25 PM
vtec.dc2's Avatar
my guess is.. oil consumption is down to 1 liter due to its being introduced back inside the block instead of being burned.. thats fine cause you don't want oil in a/f mixture.. however, i can't see why same results can't be accomplished by keeping stock separator box and pcv and just venting to atmosphere..
you're still contaminating IM through valve cover vent, maybe if you add a check valve to vent under pressure between valve cover and intake, that may reduce contamination and still have vacuum assisted ventilation. thats what i use in my boosted setup (check valve as a vent).. my valve cover vent is open at all times.. pcv valve goes to catch can then theres a t fiting with check valve that vents under wot, from there it goes to another check vavle that prevents the boost from entering engine, then it goes to IM.
Old Jun 7, 2005 | 05:30 PM
vtec.dc2's Avatar
Default Re: Endyne PCV breather system experience (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Dammit,,, Something else to spend money on.
How about a GB on this so maybe a few of us could save $ ???</TD></TR></TABLE>
with exception of catch can, you can get all this parts at honda and plumbing hardware store for almost nothing.
let me do some math right here.. i run jaz catch can and it comes with filter and it has a drain lever. plugs can't be more than few dollars from honda, then multi purpose oil resistant hoses are $1/foot, and i recommend to use brass instead of plastic fittings
Old Jun 7, 2005 | 05:36 PM
B2FiNiTY's Avatar
Default Re: Endyne PCV breather system experience (vtec.dc2)
Where did you run the hoses?
Old Jun 7, 2005 | 05:45 PM
KOALA YUMMIES's Avatar
Default Re: Endyne PCV breather system experience (B2FiNiTY)
OT: What is that wire like thing running from the hood latch to (presumably) the hood?
Old Jun 7, 2005 | 05:55 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Where did you run the hoses? </TD></TR></TABLE>
this is my latest setup.. not much differnt other than additional vent (check valve) added. this don't quite apply to n/a but check valve as additional vent can be applied to n/a setup
Old Jun 7, 2005 | 06:43 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">with exception of catch can, you can get all this parts at honda and plumbing hardware store for almost nothing.</TD></TR></TABLE>
For 2 vacuum end caps, a few feet of fuel line, and 2 empty coke bottles, you can do the same thing and see how much oil is coming out.
(for those with a stock PCV, and overfilling oil in the motor, it is a LOT OF OIL on a road course.)
Old Jun 7, 2005 | 09:17 PM
Mires's Avatar
also would like to know this as well! </TD></TR></TABLE>
I would like to know also.
Old Jun 8, 2005 | 01:56 AM
Pompiuses's Avatar
What fitting did you use for plugging the vacuum nipple on the intake manifold?
Have you tried it without using the breather filter and running a closed system? I'd guess performace would be no better than stock then because the crankcase would not be ventilated any better then stock?
Old Jun 8, 2005 | 02:02 AM
RagingAngel's Avatar
Default Re: Endyne PCV breather system experience (Pompiuses)
Glad to see you finally acted on getting "canned" Jon ...... only took about 2yrs....hehe
It's my understanding that even if you run a closed setup...it will still be a better system since the block is now able to vent from the two conveniently located plugs that are opened up in the back of the block.
(anybody ever wonder why they were put there in the 1st place? ...mystery.... )
With the catchcan being larger than stock...and I assume better baffled or about the same or better inside vs. OEM, you're likely to trap/catch more oily vapors than the stock setup.
I really like how the system can be run in street (emissions) mode and race/filter mode.
Oh and the cap on the intake manifold is just a vacuum plug.... u can pretty much get it anywhere..... silicone or rubber will do....or if you are really ghetto and stuck.... a section of hose with a large enuff bolt so it is impossible to get sucked in plus silicone for a good seal.
Old Jun 8, 2005 | 03:39 AM
SMSP's Avatar
You can get the catch can at any local speed shop or Jegs or Summit for about $60, the 2 block tube fittings come from the H22 so you get them from Honda and I think they ran me about $7 each and the freeze plug you can get at a local parts store for a buck or so.
Old Jun 8, 2005 | 04:16 AM
Pompiuses's Avatar
Default Re: Endyne PCV breather system experience (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
On the second pic in the initial post there's a red hose going from the vacuum nipple on the IM. Any idea why there's a hose there and simply not just a small plug to seal it?
Old Jun 8, 2005 | 04:38 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">What fitting did you use for plugging the vacuum nipple on the intake manifold?
I ran this way (recirculated, but with a check-valve bypass for while I was in boost).
Not as much performance benefit, but a big safety benefit. When you're sucking oil into your motor, the effective octane rating drops by 10+ points (or so I was told).
You can see video of some cars going around turn 5/6 at Expo and letting out huge clouds of smoke. I bet this is oil being sucked into the PCV.
Pep Boys by me sells vacuum line caps (conveniently). 3/8ths inch size. Buy a tiny hose clamp to hold it on, too.
-Chris
Old Jun 8, 2005 | 05:14 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">On the second pic in the initial post there's a red hose going from the vacuum nipple on the IM. Any idea why there's a hose there and simply not just a small plug to seal it?</TD></TR></TABLE>
Thats for his flux capacitor (FPR).
Old Jun 8, 2005 | 05:25 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Yup, that's exactly what I had before I switched to an open-air breather.
You may want to point your breather check valve down into an empty bottle, just in case, while on a track.
