If money was not an issue which is better, ATS, JDM, or SPOON final drive???
Old Feb 9, 2002 | 03:04 PM
hooptie157's Avatar
Default If money was not an issue which is better, ATS, JDM, or SPOON final drive???
I know I know use the seach but I have never found someone with the spoon final, does anyone have any specs on this. Is this the BEST one???
[Modified by hooptie157, 12:12 AM 2/10/2002]
Old Feb 9, 2002 | 03:10 PM
Hybrid ctr's Avatar
Default Re: If money was not an issue which is better, ATS, JDM, or SPOON final drive??? (hooptie157)
ATS
Old Feb 9, 2002 | 03:13 PM
hooptie157's Avatar
Default Re: If money was not an issue which is better, ATS, JDM, or SPOON final drive??? (Hybrid ctr)
hey hybrid you've been the man today for answering my questions thanks alot!!!
does anyone else feel the same about the ATS????
Old Feb 9, 2002 | 03:45 PM
CPR's Avatar
CPR
Another thing to consider when comparing these 3 brands is that they all have different specs. Are you concerned about the quality or performance of these products?
Old Feb 9, 2002 | 03:50 PM
hooptie157's Avatar
Default Re: If money was not an issue which is better, ATS, JDM, or SPOON final drive??? (CPR)
both, the quality and performance should go hand and hand, but I already think that ATS is better than JDM so its in between ATS and Spoon.
[Modified by hooptie157, 12:52 AM 2/10/2002]
Old Feb 9, 2002 | 03:56 PM
CPR's Avatar
CPR
My point was, in terms of quality, I'm sure all 3 of these brands will not let you down. I'm not sure I understand how you think the ATS is "better" than the JDM. I would prefer the JDM since its ratio is not as radical as the ATS so for me, the JDM is "better."
[Modified by CPR, 7:58 PM 2/9/2002]
Old Feb 9, 2002 | 06:17 PM
Spikey's Avatar
JDM 96spec and USDM FD 4.4
JDM 98SpecR FD 4.785
ATS FD 4.929
Spoon FD 4.857
Spoon FD #2 4.643 (discontinued?)
Cusco FD 5.000
Cusco FD #2 4.714 (discontinued?)
quality should not be an issue with any of these. it's not like it's gonna break on you. MAYBE certain brands are lighter than others, but I'd have to check. These are just SOME of the many FD options you have.
Old Feb 9, 2002 | 06:31 PM
hooptie157's Avatar
Default Re: If money was not an issue which is better, ATS, JDM, or SPOON final drive??? (Spikey)
thanks alot spikey that answered my question perfectly. I was also looking for the stats you included. Thanks bro
Old Feb 9, 2002 | 06:32 PM
Big Teggie's Avatar
I have never heard of anyoen with the spoon, it seems to be just right, between the 98jdm and the ats.
Cosworth's Avatar
Care to explain? The only way you can state this is if you've tested out both ATS and JDM in your car. IMO, just because ATS FD has shorter gearing (higher numerical value) doesn't mean it's better than JDM FD. Different situation asks for different solutions... I think you need to evalulate your situations before just going with brand X FD. I'm surprise you didn't mention Cusco 5.xxx FD in your lineup.
Old Feb 9, 2002 | 10:44 PM
D.Lansing's Avatar
Default Re: If money was not an issue which is better, ATS, JDM, or SPOON final drive??? (Cosworth)
Look at it this way, transmission and gear related parts are all ATS makes (at least to my knowledge). Therefore, I would expect their stuff to be really good. I've never heard anything to suggest against this either.
xunkn0vvnx
Feb 6, 2005 09:07 AM
AJ PwR
Dec 15, 2003 07:22 PM
Chris N
Nov 19, 2002 05:29 PM
RaVAGE00
May 11, 2002 06:34 AM
norice
May 3, 2002 05:15 PM
