P1399
Old Jun 7, 2005 | 02:11 PM
type_r_jon's Avatar
Default P1399
Hello fellas.
Yesterday while driving my R I shifted into 4th at approx. 8700 RPM or so. The shift felt fine but the engine didn't like it. The engine screamed for a brief minute and then the car stalled. The next morning when I started her up the engine light was on. My buddy found various misfire errors and resetted them. One code p1399 keeps comin up. The code matches to "Wait To Start Lamp Circuit" The engine is stalling when I'm sitting at a light or stop sign and it seems not to be pullin as well. I also hear a ticking sound when I drive. All bad signs I'm assuming.
Did I do the classic "money shift"?
Old Jun 7, 2005 | 02:15 PM
p nut's Avatar
$hift
What do your valves look like?
Old Jun 7, 2005 | 02:22 PM
type_r_jon's Avatar
Default Re: (P Nut)
i'm scared to look. may be bent, bent valves was a thoght i had too. I'll post when i know.
Old Jun 7, 2005 | 03:19 PM
01usjdmr's Avatar
I'll bet you bent some valves.
Old Jun 8, 2005 | 04:50 AM
type_r_jon's Avatar
Default Re: (01usjdmr)
mechanic thinks it may just need a valve adjustment based on what I told him. He's popping the valve cover tomorrow.
Old Jun 8, 2005 | 04:53 AM
nightrider's Avatar
Default Re: P1399 (type_r_jon)
so you're saying that at the top of third gear (approx 8700 rpm) you shifted to fourth gear and now you're having these problems? i wouldn't see how that is the classic money shift, but i suggest you stop driving the car until you figure it out.
Old Jun 8, 2005 | 07:04 AM
type_r_jon's Avatar
Default Re: P1399 (nightrider)
well it is the "money shift" if I caused valve damage. I'm driving to and from work whci isn't far but necessary. I know that bending valves is rare especially since R's have rev limiters and the valves are titanium if I'm not mistaken. From what I've read you have to do something really evil to bend them. I will update Friday after mechanic has looked at it.
Old Jun 8, 2005 | 04:55 PM
01usjdmr's Avatar
You probably hit second not fourth. That is about the only way it would happen.
Old Jun 9, 2005 | 05:13 AM
type_r_jon's Avatar
it felt like 4th when I shifted but coulda been. I have no compression in Cylinder one. When we addded oil we got the pressure up a bit. This led us to believe a valve is fried. Compression was also a bit lower than the other two in number 3. In the two cylinders with low or no compression have spark plugs that are very black. The engine is going to have to be rebuilt. AWESOME. 2000 bucks good bye.
Old Jun 9, 2005 | 06:21 AM
wpsadmin's Avatar
Default Re: (type_r_jon)
how fast were u going?
Old Jun 9, 2005 | 07:10 AM
type_r_jon's Avatar
Default Re: (wpsadmin)
150 ish? ? ?where is the top of the 3rd for an R somewhere around there.
I may buy a B18 B and turbo it. Or if I'm rebuilding I may as well bore it out to a 2.0 with a stroker kit.
mitcho
Sep 2, 2007 01:29 PM
n1mr0d
May 27, 2005 10:03 AM
Flux
Apr 15, 2004 07:25 PM
fredtoast
Apr 24, 2003 10:39 AM
pub
Jun 13, 2002 09:04 PM
