NEW INFO THIS IS MESSED!
Old Jun 7, 2005 | 12:46 PM
Skinflute22's Avatar
Default NEW INFO THIS IS MESSED!
okay so yesterday i posted a topic i just swapped in a d16z2 and did the mpfi conversion but during the conversion i accidently cut the big plug by the drivers side shock tower because i mis read so i re wired that and now it fires right up but then it won't turn off you have to choke it off
so today we went up and was messin wit it and decided to get the volt meter out and like the whole body is giving volts and when we hook up the battery the seat belt things in the doors click so i think i have a wicked bad short somewhere that is causing my car to stay charged even when i turn it off. does this sound like a possibility? also what is the hazard fuse its the white/green wire coming off of B1. what wires are supposed to be hot and which aren't and does anyone have any wiring diagrams. any info is greatly appreciated. thanx
Old Jun 7, 2005 | 12:59 PM
bumb need help
Old Jun 7, 2005 | 01:00 PM
FalkenSiR's Avatar
Default Re: NEW INFO THIS IS MESSED! (Skinflute22)
Damn that sucks *** man. I would get a helms for the diagrams and go from there. I don't know what else to say, you just fucked up real bad
Old Jun 7, 2005 | 01:28 PM
up
Old Jun 7, 2005 | 03:03 PM
NikoZai's Avatar
Default Re: (Skinflute22)
Leave it to the professionals next time
http://www.rywire.com
We can fix it for you if it's only cut on the Engine harness side. Otherwise it's too hard to ship the interior harness, good luck!
Old Jun 7, 2005 | 03:25 PM
i'll talk to you on aim keep the info comin
Old Jun 7, 2005 | 04:32 PM
ServiceAdvisor's Avatar
This is a horrible pic of the harness and where the wires go and their colors. Make sure when you pin them into pos, your looking straight @ them. And then follow this pic and it should be fine.
The bottom is the bigger 1, where the smaller top 1 plugs into it. This is exactly how its wiring on my 91 Si.
Old Jun 7, 2005 | 04:59 PM
SETI20's Avatar
sounds a little bit like you hooked up a positive to a ground lead... BZZZZZZZZZZZZ
Old Jun 7, 2005 | 05:02 PM
i'm not sure does anyone know the layout of the dx plug that is above the drivers side shock tower?
Old Jun 7, 2005 | 05:51 PM
mr-mister's Avatar
this looks just like the other post you made with the same topic
Old Jun 7, 2005 | 07:08 PM
haha.. go blow ur dad
Old Jun 8, 2005 | 01:31 PM
up does anyone know of there dx drivers side firewall plug if it has 2 yellow black on the male side or 3 cuz mine has 3 on one side and on the female side it only has 2 but then on the male side it has 1 black yellow.......wtf?
Old Jun 8, 2005 | 01:35 PM
also it revs up to like 2000 rpms uncontrolably
Old Jun 8, 2005 | 04:09 PM
UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 8, 2005 | 04:44 PM
FalkenSiR's Avatar
mr-mister your sig is ****** disgusting... lol
Keeper1343
Aug 29, 2007 06:16 AM
JDM92hatchy
21
Aug 17, 2006 04:32 PM
cor0780
Mar 6, 2006 05:02 AM
