knock sensor for B20VTEC help?
Old Jun 7, 2005 | 12:02 PM
B18ek's Avatar
Default knock sensor for B20VTEC help?
Do B20s have a knock sensor? If no how did you wire this up for B20vtec?
tryed a search but found nothing.
Old Jun 7, 2005 | 06:32 PM
hybridpatient95's Avatar
Default Re: knock sensor for B20VTEC help? (B18ek)
run a seperate wire from the knock sensor to your inside harness where the ecu plugs into.. it should go to pin number d3
Old Jun 7, 2005 | 07:11 PM
Fobtions's Avatar
Default Re: knock sensor for B20VTEC help? (frankenfiend 04)
i think he means where does he put the knock sensor.
i always use one of the alternator bracket bolts, you will need to retap accordingly.
Old Jun 7, 2005 | 07:36 PM
yea you would need to retap it.. my friends b20z2 came with a knock sensor could be cuz its a 2000 block
Old Jun 9, 2005 | 07:43 PM
B18ek's Avatar
Default Re: knock sensor for B20VTEC help? (Fobtions)
Got some info off hybridhonda, it said knock sensor don't need to be hooked up just has to be grounded? dis right? I already have a engine harness w/ a knock sensor hooked up to a B18c, w/ 95 P72 ECU, bout to put in the B20 block,just need to know where to plug in, also no PCV box on the back of B20's?
Old Jun 9, 2005 | 07:49 PM
Kendall's Avatar
Or you could use an engine management system that allows the knock sensor to be disabled.
Old Jun 9, 2005 | 08:03 PM
mtber's Avatar
Default Re: (Kendall)
You could run a chipped ecu with the knock sensor disabled so you don't have to wire it. Considering the factory knock sensor is crap, that is what I would recommend.
Check out phearable.net
Old Jun 9, 2005 | 08:27 PM
Andres-eh2's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">Most of the work on the shortblock is finished. On to the head next.
Adding a knock sensor and alternator install[/b]
Old Jun 13, 2005 | 02:10 PM
B18ek's Avatar
Default Re: (Andres-eh2)
How far in did you tap? Does it have to be completely through? Or just enough to screw in the knock sensor?
Old Jun 13, 2005 | 02:38 PM
chechin's Avatar
Why shouldn't use a knock sensor?, I think it's very important to prevent a premature sleeve cracking, am I right?
Old Jun 27, 2005 | 02:57 PM
getnasty's Avatar
Default Re: (chechin)
alright im haveing problems... my b20 vtec needs a knock sensor.. does it have to go all the way into the block or just deep enough to fit the sensor in?
93SiVTEC16794
Nov 22, 2013 01:36 AM
97blacklude
Jan 31, 2009 09:56 AM
95redeg6
Apr 28, 2007 10:23 AM
93NXLUDE
Mar 5, 2003 06:32 PM
