how do u know if u spun a bearing
Old Jun 7, 2005 | 10:20 AM
b16a27's Avatar
Default how do u know if u spun a bearing
ok i just got a engine rebulid and it makes like a high pitch rattle or squel BUt its not a belt its coming from inside the block or headbut the head is still stock so i think its a bearing what are some signs of a spun bearing like sounds performance loss any thing thaks
Old Jun 7, 2005 | 10:36 AM
snatch's Avatar
Default Re: how do u know if u spun a bearing (b16a27)
I'm pretty sure if you have a spun bearing...engine no worky.
Old Jun 7, 2005 | 10:40 AM
b16a27's Avatar
Default Re: how do u know if u spun a bearing (******)
ok because its scaring the **** out of me i just threw like 3k into it and now its making sounds its scarywhat do u think the sound can be then?
Old Jun 7, 2005 | 10:43 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
No if you spin a bearing, you will hear the rod slapping. You will definatly know the sound. Check your timing belt, it may be too tight or rubbing on something.
Old Jun 7, 2005 | 10:44 AM
b16a27's Avatar
Default Re: how do u know if u spun a bearing (JDM_Ej)
but its off and on mostly when i start the car up it will come and go its radom but uselly when i start the car up it will do it
Old Jun 7, 2005 | 10:46 AM
slotec's Avatar
did u replace the throwout bearing with a new one inside the tranny and pilot bearing?
Old Jun 7, 2005 | 10:52 AM
ZedEx's Avatar
The sound you're describing sounds like a bad Throw Out Bearing (Like slotec stated)
The Throw Out Bearing has gone bad in my Z6, causing a horrible tapping sound. Do this, press in your clutch, if the noise stops, or gets less audible... It's more than likely your throw out bearing.
Here is a video sample of what mine sounds like from under the car.
Short clip with me under the car about a foot or so away from the Bell Housing. Activating the clutch by hand.
Another short clip with me sitting in the drivers seat
They're night shots, but if you can deffinately hear the difference... Just crank the volume up a bit
Old Jun 7, 2005 | 11:50 AM
snatch's Avatar
Default Re: (ZedEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZedEx &raquo;</TD></TR><TR><TD CLASS="quote">The sound you're describing sounds like a bad Throw Out Bearing (Like slotec stated)
Bad mainshaft and countershaft bearings inside the tranny can also sound like this too.
Old Jun 7, 2005 | 08:15 PM
slotec's Avatar
Default Re: (******)
i say its most likely your tranny making the noise or could be really anything i guess pop the hood and see where u know u definately hear it
young-gun92eg
Jun 13, 2013 01:23 PM
petergriffen
Feb 25, 2007 05:15 PM
davidluko
Jan 21, 2007 03:57 PM
b16a27
Jun 4, 2005 10:46 AM
