car wont go above 3400.....at all plz help
Old Jun 7, 2005 | 09:49 AM
MangoKid84's Avatar
Default car wont go above 3400.....at all plz help
ok, well i have a 91 civic dx and it wont go above 3400 rpm and it back fires alot, only codes on it are o2 sensor and TDC/Crank ive unplugged my o2 sensor too. If you could tell me why its doing this i would be very appreciative.
Old Jun 7, 2005 | 09:50 AM
xDicktonesx's Avatar
Default Re: car wont go above 3400.....at all plz help (MangoKid84)
distributor
Old Jun 7, 2005 | 12:34 PM
Mach69's Avatar
Default Re: car wont go above 3400.....at all plz help (CRXofPain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain &raquo;</TD></TR><TR><TD CLASS="quote">distributor</TD></TR></TABLE>
Please dont just to that conclusion just yet. The TDC code is what is causing the problem. You should check for continuity between the ECU and the distributor in the wires FIRST. I forget where on the ecu it is. Also make sure the connection at the distributor and ecu are good, if you need to, resolder the connection at the ecu. If you still have a code after that, then I would get a new distributor. I am 90% sure it will be the distributor that is causing you problems.
Old Jun 8, 2005 | 06:09 AM
MangoKid84's Avatar
Default Re: car wont go above 3400.....at all plz help (Mach69)
appreciate the help if there are any more problems i will post back
Migs19
Sep 7, 2016 12:32 PM
Carlos Peralta
Jan 13, 2013 05:43 PM
jdmeg1075
May 22, 2008 03:52 PM
blk89crx
Oct 28, 2005 11:46 AM
CivicHatchback14
Jul 14, 2004 12:00 PM
