turbo installed, car wont start
Old Jun 7, 2005 | 09:01 AM
Turbo_Mike's Avatar
Default turbo installed, car wont start
I just put a turbo on my 91 civic with b16. I converted it to obd1 in the process, so there is too many questions and not enough solutions to trouble shoot. I bought an obd0-1 jumper, chipped p28, and a obd1 dizzy that was coverted to obd0 plugs.
It turns over fine...i smell gas, but it wont fire. I'm gonna go check for spark now. I'm afraid that maybe i got a bum distributor but i just wanted to make sure there wasnt anything else i was overlooking. Charge pipes arent hooked up, theres no o2 sensor, no downpipe. NOne of this which would affect the car starting.
Anything else i should look ?
Old Jun 7, 2005 | 10:30 AM
Redline130's Avatar
Default Re: turbo installed, car wont start (mike dyke)
Check all your grounds and fuses. I would check for spark first however.
Old Jun 7, 2005 | 11:38 AM
Turbo_Mike's Avatar
Default Re: turbo installed, car wont start (Redline130)
No spark...all grounds look good.
I had my under dash fuse panel un bolted and i thought that was it, but it wasnt.
Old Jun 7, 2005 | 12:14 PM
Turbo_Mike's Avatar
There's only one way to put the dizzy in , correct?
Old Jun 7, 2005 | 03:34 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike dyke &raquo;</TD></TR><TR><TD CLASS="quote">There's only one way to put the dizzy in , correct? </TD></TR></TABLE>
Yup, the gear is offset to match the cam. I would recheck your wiring, especially at the distributor...make sure everything matches up.
Old Jun 7, 2005 | 05:16 PM
Turbo_Mike's Avatar
I really cant check the wiring. I bought a jdm concepts conversion harness, but all the wires on it are black. I bought an obd1 dizzy with obd0 plugs already on it. The big round obd1 plug has all black wires and one yellow. REAlly no way i can go back to check all the wires by color matching.
Old Jun 7, 2005 | 05:27 PM
mr-mister's Avatar
backtracking always sucks but have you tried to crank it over with all of your old obd0 components?
Old Jun 7, 2005 | 05:32 PM
Turbo_Mike's Avatar
Default Re: turbo installed, car wont start (mr-mister)
yea i put it back on and it runs fine
Old Jun 7, 2005 | 05:48 PM
mr-mister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike dyke &raquo;</TD></TR><TR><TD CLASS="quote">yea i put it back on and it runs fine</TD></TR></TABLE>
Is there any special reason you have to run obd1 RIGHT at this instant? Im thinking yor concerned about tuning probably but you might have to just hold off on the obd1 untill you get a legit dizz
Old Jun 7, 2005 | 06:54 PM
Turbo_Mike's Avatar
i can run obd0 on stock map and injectors, i dont know how the turbo is gonna like that though
thatHEMIguy
28
Nov 28, 2010 08:53 PM
peeka
Mar 31, 2009 02:45 PM
d15.hatch
Jan 30, 2006 10:49 AM
menappi
Sep 21, 2005 03:41 PM
Turbo_Mike
Jun 8, 2005 05:22 AM
