Suspension & Brakes Theory, alignment, spring rates....
D brackets for swaybar bushings-rear
Old Jun 7, 2005 | 08:53 AM
DC4_MADMAN's Avatar
Default D brackets for swaybar bushings-rear
To use a JDM ITR rear swaybar and bushings(23mm) what d brackets do I need?
Can I just use standard Teg brackets or do I need to order a set of ITR brackets from Honda?
If I need the ITR ones does anyone have the part number?
Thanks.
Old Jun 7, 2005 | 09:11 AM
CivicFerio's Avatar
Default Re: D brackets for swaybar bushings-rear (4door_demon)
You should be able to use the regular ITR 22mm D brackets.
Part Number 52308-SS0-000 List 6.67
Charleston
b18c4door
Jan 30, 2007 05:02 PM
1337 Si
Oct 22, 2006 02:41 AM
R-Lug
Suspension & Brakes
Sep 28, 2006 10:49 PM
comptechgsr
Sep 15, 2002 12:00 AM
