Suspension & Brakes Theory, alignment, spring rates....
how do you tell which springs go on the front and which go on the rear??????
Old Jun 7, 2005 | 07:47 AM
DRKSol's Avatar
Default how do you tell which springs go on the front and which go on the rear??????
i got some springs 1.9 in front and 1.7 in the rear... how do i tell which go where? would the shortest spring go in the front?
Old Jun 7, 2005 | 08:44 AM
97L-esVeeTeg's Avatar
Default Re: how do you tell which springs go on the front and which go on the rear?????? (jh)
Most springs have an F or an R printed on them after the number.
Old Jun 7, 2005 | 11:14 AM
stuck209's Avatar
Default Re: how do you tell which springs go on the front and which go on the rear?????? (97L-esVeeTeg)
First two springs are for the rear. You can tell that the coil is much closer together then the front. Thats what I go by.
Old Jun 7, 2005 | 11:55 AM
CerealWars's Avatar
Default Re: how do you tell which springs go on the front and which go on the rear?????? (stuck209)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stuck209 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Thats not always right. I thought the same way till I called the maufactor of my springs just to make sure I was right...I was wrong. Your better off just calling them and asking.
Old Jun 7, 2005 | 12:47 PM
DRKSol's Avatar
thanks alot. thats what i thought but not sure if i was right
AllmotorGSReg
Apr 23, 2009 05:57 AM
mike9571
Suspension & Brakes
13
Dec 6, 2005 07:31 PM
Solracer
22
Nov 3, 2004 02:47 PM
2 point 0
30
Apr 10, 2004 08:52 PM
CD5 Sedan
Oct 30, 2002 04:53 PM
