test pipe question
Old Jun 7, 2005 | 06:59 AM
sickofitall1113's Avatar
Default test pipe question
where does the o2 sensor go when you put a test pipe on. if my memory serves me right there is an o2 sensor in the cat...but i could be mistaken. if there is what do you do with it and wouldn't a test piep make you throw a check engine code? if theres no o2 sensor feel free to flame me to the ground
Old Jun 7, 2005 | 07:00 AM
LSracing94's Avatar
Default Re: test pipe question (sickofitall1113)
i put mine in the collector of the header
Old Jun 7, 2005 | 09:27 AM
EKB18BPR3's Avatar
test pipe replaces the cat and o2 sensors are not on the cat.
Old Jun 7, 2005 | 09:32 AM
HoUTX98GSR's Avatar
you can get you ecu chipped to not look for it, or they make a little o2 sensor simulator thingy to make the ecu think that its still there so you wont throw a code. or you can just put it in the collector like ^^^. but youll have to tap out a new hole for it.
Old Jun 7, 2005 | 09:40 AM
honda011's Avatar
Default Re: test pipe question (HoUTX98GSR)
if you put it in a collector u won't be throwing a code?????
Old Jun 7, 2005 | 10:03 AM
Default Re: test pipe question (honda011)
well ok...first...is there an o2 sensor in the cat...cuz there was 2 different answers here. and they do make ones with a spot for it on the pipe...just gotta find one i guess.
Old Jun 7, 2005 | 10:13 AM
rough_draft's Avatar
can't you just wrap some foil around it and zip tie it or something?
Old Jun 7, 2005 | 10:17 AM
xteg95's Avatar
Default Re: test pipe question (98B00STED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">test pipe replaces the cat and o2 sensors are not on the cat. </TD></TR></TABLE>
wrong...obdI has 1 o2 sensor in the exhaust manifold, odbII has two o2 sensors, 1 in the exhaust manifold and 1 in the cat (i think thats how it goes). so depending on the year of your car you may or may not have 2 o2 sensors. you can get an o2 sensor welded into your test pipe but its still going to throw a CEL, otherwise you can get that o2 simulator thing.
Old Jun 7, 2005 | 10:34 AM
dFreezy's Avatar
Default Re: test pipe question (xteg01)
xteg01 is correct. there is no real point to having that O2 sensor hole on a test pipe other than to have your O2 sensor not dangling there. you will still get a CEL.
Old Jun 7, 2005 | 07:06 PM
Default Re: test pipe question (dFreezy)
wil it kill my gas milage having one o2 sensor not connected?
Old Jun 7, 2005 | 08:54 PM
brickonwheels's Avatar
haha, i am running no o2 sensors to my ecu, only one for my a/f gauge
Old Jun 8, 2005 | 01:13 AM
Bibnation3's Avatar
i have a obd2 integra and i have two 02 sensors. i welded the second on into the pipe also and i have no CELs or anything. Been almost half a year now since i got the test pipe done to my car now and i get no CELs
Old Jun 8, 2005 | 05:27 AM
Wraith_G2IC's Avatar
Default Re: (Bibnation3)
As someone stated before:
OBD1 = 1 o2 in the exhaust manifold/header
OBD2 = 2 o2, one in the manifold, one in the cat
First of all, why are you asking about a test pipe? If you are track only then knock your self out, but if you are street then why do this irresponsible mod? You increase you chance of getting lung disease not to mention the poor bastards that get stuck behind you. All the while you are living the stereotype of a "ricer". You will not pass emissions, you WILL loose some low end, and the exhaust will sound like ***. Why 1/2 *** it? You can just buy a 200 or 300 cell high flow cat for less than $200 with the proper o2 bung.
Modified by Wraith_G2IC at 4:41 PM 6/8/2005
Old Jun 8, 2005 | 06:46 AM
LSracing94's Avatar
Default Re: (Wraith_G2IC)
increasing your chance of lung disease might be going a little far..but yea..all the rest is right
Old Jun 8, 2005 | 09:17 PM
Default Re: (LSracing94)
will it screw up my gas milage if the o2 sensor isn't connected? no one ever answered that
Old Jun 8, 2005 | 10:07 PM
iH8RICERZ's Avatar
Default Re: (sickofitall1113)
hrmm, wierd...my o2 sensor on my 94 gsr has always plugged into my cat, instead of my exhaust manifold (Running DC 4-2-1) . Also, on my comptech test pipe, there's 2 spots for 2 o2 sensors. I have an o2 bung plug to plug the one, and plug in my o2 sensor in the other......
As for gas milage, if your car is throwing a cel/s, most likely your ecu will go into limp mode and run like dookey....thus, not good gas mileage.
Old Jun 9, 2005 | 12:18 PM
xteg95's Avatar
Default Re: (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">
As for gas milage, if your car is throwing a cel/s, most likely your ecu will go into limp mode and run like dookey....thus, not good gas mileage.</TD></TR></TABLE>
ive had a CEL for about a year because of my gutted cat and still get 300-350mi per a 11.5-12 gallon fill up
mxracer420
Mar 25, 2010 04:33 PM
rebuiltSI
Jun 29, 2007 05:56 AM
IntegraCF21
Sep 24, 2005 04:42 AM
Chris_Bye
May 1, 2005 07:56 AM
