Bumper wont stay on fender
Old Jun 7, 2005 | 06:19 AM
B18EG6's Avatar
Default Bumper wont stay on fender
Hello-
Not too long ago a tow truck driver was so nice as to rip my bumper clean off, and tore the tab where it connects to the fender.
I was thinking about getting some quick release fasteners to hold it on at the fenders, something like this:
Or some Dzus fasteners
Has anyone had any experience with either of those?
I took them from http://www.pegasusautoracing.com .
Old Jun 7, 2005 | 06:34 AM
pdiggitydogg's Avatar
Id just mount (rivet) a strip of something across the torn spot and add a new hole
Better than pop clips that people can play with
Old Jun 7, 2005 | 06:38 AM
Hurricane's Avatar
Default Re: (pdiggitydogg)
WTF is wrong with tow truck drivers, its been 20+ years since you could tow a car by the bumper.
Old Jun 7, 2005 | 06:54 AM
papito_85's Avatar
i had the same problem.
Old Jun 7, 2005 | 07:11 AM
nocturnaldragon's Avatar
Default Re: (Hurricane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hurricane &raquo;</TD></TR><TR><TD CLASS="quote">WTF is wrong with tow truck drivers, its been 20+ years since you could tow a car by the bumper.</TD></TR></TABLE>
He might of had the sling type tow where sometimes because a car is lowered, hits the sling while lifting it up. Thats the kind of tow truck I drive and it sucks to lift lowered cars and even some stock cars too. You dont actually tow it by the bumper but the sling hit it going under it so the arms can hit the suspension which is what you tow by.
Old Jun 7, 2005 | 07:23 AM
Cripsaks808's Avatar
what you do is grab a scrap peice of sheet metal rivet it over the whole drill a new hole into the sheetmetal and you should be fine i rigged a whole new arm to hold the plastic peice on my CRX
Old Jun 7, 2005 | 09:25 AM
built562's Avatar
Default Re: (Cripsaks808)
^^^^^ go with what he said
you can also get in there and just drill sheet metal screws up through the bumper and fender from the underside like where your hole is ripped. this will also take care of the saggy eg bumper syndrome
Old Jun 7, 2005 | 09:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cripsaks808 &raquo;</TD></TR><TR><TD CLASS="quote">what you do is grab a scrap peice of sheet metal rivet it over the whole drill a new hole into the sheetmetal and you should be fine i rigged a whole new arm to hold the plastic peice on my CRX</TD></TR></TABLE>
Isnt that what I JUST said??
Old Jun 7, 2005 | 09:35 AM
SRCivic97's Avatar
Default Re: (built562)
Or another solution which is what I did. Get yourself an 11mm bolt and use some oversized washers to help eliminate the gap that was caused by the missing piece. This should do the trick nicely.
Old Jun 7, 2005 | 10:27 AM
s.patel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Id just mount (rivet) a strip of something across the torn spot and add a new hole
Better than pop clips that people can play with</TD></TR></TABLE>
I did something similar to this using a piece of sheetmetal and I havn't had any problems with it at all.
I sandwiched the messed up part with 2 pieces of sheetmetal that bolted together and drilled a new mounting hole. It cost me about 2 bucks just for nuts and bolts.
Modified by s.patel at 11:48 AM 6/7/2005
Old Jun 7, 2005 | 08:13 PM
B18EG6's Avatar
Default Re: (s.patel)
Awesome, thanks for all the ideas fellas.
Ima go ahead and do this ^^^ and rivet it to the underside of the bumper.
Thanks again! YAY for no ugly quick release latches!
SilverWarrior
Oct 7, 2007 03:17 PM
Mattmob
10
Aug 22, 2005 11:10 AM
Rocco.
Jan 17, 2005 08:23 AM
grlstockb18c1
Jun 11, 2004 01:05 PM
B18EG6
22
Aug 16, 2003 05:41 PM
