shaking
Old Jun 7, 2005 | 05:45 AM
hondaaccord94's Avatar
Default shaking
i have a h22a motor in my accord.my car shakes crazy at 45 to 70 mph.before 40 and after 70 the car doesnt shake at all.i had the wheels balanced and i had a allignment done to it.i did a rotation i have tried everything on it nothing helps.i do have a little bend in the front right rim.i have 17'' rims with stock suspension.the mechanic told me that the little bvend i have in my rim is not causing that problem.so if anyone knows what my problem could be please reply.thanx
Old Jun 7, 2005 | 07:41 AM
Duane_in_Japan's Avatar
Default Re: shaking (hondaaccord94)
borrow two tires from someone and go on another test drive.
Duane in Japan
Old Jun 7, 2005 | 07:42 AM
Vt4kpwn35's Avatar
Default Re: shaking (Duane_in_Japan)
Has this happened since the swap or is it new?
Old Jun 7, 2005 | 07:58 AM
Default Re: shaking (95cd7)
it happened right when i got the swap.so u guys think it could be tires then?because these tire are not cheap man and i have a warranty on them so i think im just take it back to the shop and get my money.
Old Jun 7, 2005 | 08:09 AM
NAiL05's Avatar
U said u had stock suspension right?? WEll id give that a look over. H22A is a heavy motor and that motor is heavier than ur stock accord motor. So i would go and give that a look over.
Old Jun 7, 2005 | 08:23 AM
Default Re: (NAiL05)
so basically ur saying to get some better suspensions.and what kind of suspensions do u suggest.i was thinking about eibach pro kit but dont know how that will work out.
Old Jun 7, 2005 | 08:30 AM
NAiL05's Avatar
you also need an aftermarket shock cuz either way that motor will compress ur stock front suspension so no shock travel. no shock travel = blown shock which is dangerous especially if ur driving. Ive heard good things bout eibach pro kits. Personally id go with a full coil over set but thast if u got the money. But spring and shock works also and its less stiff.
Modified by NAiL05 at 9:52 AM 6/7/2005
Old Jun 7, 2005 | 09:21 AM
thanx guys i appreciate that
Old Jun 7, 2005 | 12:22 PM
H2290's Avatar
Default Re: (hondaaccord94)
Have you actually ruled out tires/wheels yet? Just swap some with a friend who doesn't have such a problem and see what happens. Try that before you go swapping out your whole suspension. I have a H22 in my 90 with stock suspension and no such problems.
Old Jun 7, 2005 | 03:17 PM
NAiL05's Avatar
Yes u can do what h2290 said first. But i would recommend changing suspension in the long run cuz ur stock suspension isnt gonna be reliable.
Old Jun 7, 2005 | 07:10 PM
H2290's Avatar
Please don't get the wrong impression. I am on my stock suspension and it is not doing what you said but I do agree with Nail that a better suspension setup should be in order after this swap. I haven't gotten to mine yet, but it is most definitely still a good idea. Not saying it will solve your problem or not but you should still do it.
Old Jun 7, 2005 | 07:25 PM
DreamAtlantis's Avatar
I had the same problem with mine, shaking at a certain speed, mine was at 60 mph (Though I have no H22 Swap) and it was the slight dent on the front rim. I even got the spacers I think they're called. Once I switched it and put it on the back it ran fine. Just make sure the rotation's the same.
Old Jun 9, 2005 | 01:21 PM
SloCrxDx91's Avatar
I use to work in a tire center and usually when I here this the most common problems are tire balancing, alignment, factory defect in tire, lack of rotation which can cup tires.
vtec31
Apr 10, 2015 11:25 PM
H22A_HB
Dec 13, 2004 11:59 AM
H22A_HB
Dec 13, 2004 11:42 AM
LivinDreamsEK9
Apr 9, 2004 12:34 PM
94ludestockS
Jun 5, 2002 02:59 PM
