what can i run safely on my b16a1 with a greddy turbo
Old Jun 6, 2005 | 09:29 PM
folta2169's Avatar
Default what can i run safely on my b16a1 with a greddy turbo
i have a stock internal b16a1 and i am in the process of getting a full greddy turbo with inner cooler and blow off valve and all.
Old Jun 6, 2005 | 09:31 PM
90sohcHATCH's Avatar
Default Re: what can i run safely on my b16a1 with a greddy turbo (folta2169)
w/ a VAFC hack and good injectors and a good fuel pump i say you could run 10-13 pounds all day long
Old Jun 6, 2005 | 09:39 PM
vw eater's Avatar
any pic's..?
Old Jun 7, 2005 | 12:15 AM
crxnj's Avatar
Default Re: (vw eater)
Keep it under 10lbs of boost if using the greddy bluebox and stock injectors..
Old Jun 7, 2005 | 12:48 PM
Drkaccrd's Avatar
Stay as far away as possible from the the hack..... It sucks ballz!!!! if your gonna run higher boost get bigger injectors, hondata .......you should be good to go...
Old Jun 7, 2005 | 01:53 PM
jamclaur's Avatar
Don't get hondata... Get uberdata... Much cheaper and does the same thing. I wouldn't personally run more than 10 lbs of boost on stock internals. But that's just me.
Old Jun 7, 2005 | 03:55 PM
kaoss_11's Avatar
B A N N E D
Uberdata is cheaper in price but overall hondata is better and not because i have hondata but because i looked into both options. If you want to boost 13 psi on a stock block go for it, but i see no future for your motor. Also buying my 450 cc injectors and msd fuel pump will help you alot
gsr x civic
Nov 27, 2007 04:12 PM
JDM 93 EJ1
Jan 20, 2005 09:43 AM
SupaTeg
Dec 10, 2003 10:29 PM
zojirushi
Mar 9, 2003 02:32 PM
WykidEH
Oct 12, 2001 03:38 AM
