which is the better stock radiator to go with????? powering a b16 motor project
Old Jun 6, 2005 | 09:25 PM
asocallocal's Avatar
Default which is the better stock radiator to go with????? powering a b16 motor project
i have a b16 with compression of 11.6-1 in a 92-95 civic.
what is better to use and why? AND what should i use? is there a difference between each duel core?
1>stock eg radiator(single core)
2>del sol (duel core)
3>99 si ( duel score)
4>integra radiator
i dont have a/c or power steering.
Old Jun 7, 2005 | 04:44 AM
dwnthehatch's Avatar
Default Re: which is the better stock radiator to go with????? powering a b16 motor project (asocallocal)
The 99/00 si and del sol dual core are the same radiator. I would go with them since it's a direct bolt in and you don't have to make brackets to mount it like you would with the teg radiator.
Old Jun 7, 2005 | 05:32 AM
drunknbass's Avatar
i mounted a itr radiator in my eg and it wasa tight fit, but it keeps the motor cool and hmotorsonline.com sells them with fan for like 40-50 $ and they are usally mint condition.
had to purchase 2 integra top brackets and drill holes in the rad support to fit them, and drill the welds out of the lower brackets and remove them and reposition them and re attach them.. oh yea i had to notch my cf hood to close cause it hit the top brackets
Natural Aspirations
19
Jun 14, 2009 05:48 PM
94eh2
12
Sep 14, 2007 04:41 PM
teamvirus
Dec 17, 2005 08:08 PM
asocallocal
12
Jun 2, 2005 09:04 AM
Chicano
Apr 21, 2005 04:54 PM
