coolant temp. sensor problem
Old Jun 6, 2005 | 09:25 PM
folta2169's Avatar
Default coolant temp. sensor problem
i am throwing the coolant temp. sensor code, so i replaced the sensor twice. what could be the problem.
Old Jun 6, 2005 | 10:17 PM
R_type's Avatar
Default Re: coolant temp. sensor problem (folta2169)
are your wires messed up or are they grounding anywhere.... cause for that sensor all it needs is for those to wires to complete a circuit and if its grounded somewhere else that might be why you are throwing codes
Old Jun 7, 2005 | 05:23 AM
jlicrx's Avatar
are you replacing the correct sensor? on the end of the head below the distributor - has 2-wire connector with red/white and green/white wires
Old Jun 7, 2005 | 08:18 AM
seekerONE's Avatar
just a guess because you gave so little information...
Is this a b16 into an crx hf? if so there AND the code 6 set right after putting into reverse...then the issue is with the extra un-needed wire going into the ecu for the back up light switch. The HF needed it but the JDM B16 ecu doesn't. GREEN wire with BLACK STRIPE. i don't remember the actual localtion.
Old Jun 8, 2005 | 11:30 PM
folta2169's Avatar
Default Re: (seekerONE)
ok thanks but here is some more info.......i have 3 codes blinking( knock sensor, coolant temp sensor, and the #1 o2 sensor) my v-tec doesn't work and i am guessing it is because of the check engine light. On top of it all, the wires going to the cd player and **** and the turn signals all quit working. Hopefully this helps but just ask me if you need to know more. I need help ...thanks
710dabber
Nov 5, 2015 12:36 PM
traxxasx
May 27, 2015 01:50 AM
EFLS89
12
Jan 12, 2010 12:54 PM
boosting101
Aug 19, 2009 08:08 AM
foress_89
Jan 15, 2008 03:58 PM
