Eg b18c1 help?
Old Jun 6, 2005 | 06:23 PM
shyboi4u's Avatar
Default Eg b18c1 help?
can anyone tell me wat is wrong when i accelerate around 3k rpm i feel the passenger wheel vibrate? shifting from 1st gear to 3rd gear. Also i want to get a skunk 2 intake manifold. i notice on my friends that he has one. the only thing i don't like is that the stock throttle body makes the throttle cable bracket higher. he had bought a typer r throttle cable cuz he thought he needed it but he can't use it. or can you get another bracket off a b18b or b16? it like the first thing you see when you open the hood. much help needed. thanks
Old Jun 6, 2005 | 10:09 PM
Jedi_Sol's Avatar
Default Re: Eg b18c1 help? (shyboi4u)
I thought the engine was the first thing u see when you open the hood. jk.
Sounds like a worn axle.
James.
Old Jun 6, 2005 | 11:10 PM
DJ_NeX's Avatar
Default Re: Eg b18c1 help? (Jedi_Sol)
could be a worn axle, axle not locked into the tranny completely, or even just lug nuts that aren't tight.
Old Jun 7, 2005 | 01:52 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Eg b18c1 help? (DJ_NeX)
check the cv boots for leaks or cracks.
Old Jun 7, 2005 | 12:32 PM
shyboi4u's Avatar
my axles are brand new. i had them changed twice cuz the other axle broke on me on the interstate. and everything is tight.
Old Jun 7, 2005 | 12:48 PM
IHateJDM's Avatar
wheel bearing?
Old Jun 7, 2005 | 12:51 PM
mike1114's Avatar
Default Re: Eg b18c1 help? (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearing?</TD></TR></TABLE>
You can use the bracket for the throttle cable from the LS or ITR to relocate the cable.
Old Jun 7, 2005 | 04:44 PM
shyboi4u's Avatar
nope, new wheel bearing
Old Jun 7, 2005 | 04:46 PM
shyboi4u's Avatar
Default Re: Eg b18c1 help? (mike1114)
you change it off the throttle body right? and get the other bracket that on the manifold from them too?
Old Jun 10, 2005 | 06:48 PM
shyboi4u's Avatar
some1! plz help
Old Jun 10, 2005 | 07:05 PM
Brodie Bruce's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u &raquo;</TD></TR><TR><TD CLASS="quote">you change it off the throttle body right? and get the other bracket that on the manifold from them too?</TD></TR></TABLE>
Yes, you are right. You will need the throttle cable linkage (the thing that is wound by a spring on your throttle body) from any integra other than a GSR and you will also need the throttle cable bracket that goes on the intake manifold from an Integra type R(other Integras might work but the type R will for sure)
kraquepype
30
May 10, 2018 08:48 PM
bigmacnfries
Honda S2000
Aug 9, 2015 08:32 PM
Pagley
Jun 29, 2008 03:56 PM
koulaid
Nov 28, 2006 01:13 PM
IntegD
Oct 30, 2002 07:28 AM
