azenis rt615 track tire pressures??
Old Jun 6, 2005 | 06:13 PM
Freeltec's Avatar
Default azenis rt615 track tire pressures??
what should i be running on the track in cold psi.
i am asking b/c the new azenis have softer sidewalls then the old ones..
should i be equal fromt to rear? i did 35psi all around... and my car seemed tail happy when the tires were hot.
Old Jun 6, 2005 | 06:14 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: azenis rt615 track tire pressures?? (Freeltec)
i used 37 and it seemed okay. yeah sidewalls a little softer, but i really liked the tires at 37
Old Jun 6, 2005 | 06:25 PM
Freeltec's Avatar
Default Re: azenis rt615 track tire pressures?? (rino924)
37 all around? cold or hot pressure??
Old Nov 1, 2005 | 07:09 PM
92 CIVIC HATCH VX's Avatar
when draging i run 20psi and hook alright in autocross i don't know.
dropping to 20 made my 60's 2.1
Old Nov 1, 2005 | 08:22 PM
BlueTeg's Avatar
37 is way too high IMO for that tire.
Should be around 30-35 psi depending on your setup and the track conditions.
Old Nov 1, 2005 | 08:25 PM
BlueTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">when draging i run 20psi and hook alright
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freeltec &raquo;</TD></TR><TR><TD CLASS="quote">what should i be running on the track in cold psi....and my car seemed tail happy when the tires were hot.</TD></TR></TABLE>
Doesn't sound like he's asking for suggestions for dragging the car.
Old Nov 2, 2005 | 07:15 AM
Jon D's Avatar
I have tracked these twice and cold i had them at 35 psi all around. The side walls are definitely softer but i have nothing negative to report about them.
edit: i too experienced some tail happiness!
Old Nov 2, 2005 | 02:48 PM
Circuit Star-29's Avatar
Default Re: azenis rt615 track tire pressures?? (Jon D)
Post suspension setup:
I run 40/30 and the tires do very well...Lots of info in the R/R forum, too.
Old Nov 2, 2005 | 04:18 PM
1GreyTeg's Avatar
Default Re: azenis rt615 track tire pressures?? (C-speed Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racer &raquo;</TD></TR><TR><TD CLASS="quote">Post suspension setup:
I run 40/30 and the tires do very well...Lots of info in the R/R forum, too.</TD></TR></TABLE>
40/30 hot or cold?
Old Nov 2, 2005 | 04:19 PM
Default Re: azenis rt615 track tire pressures?? (1GreyTeg)
^^^ Hot...although it would be interesting to see what the tires do over an "extended" session. So far I've only seen temps of 160 after a 35 min session.
Old Nov 2, 2005 | 04:31 PM
visi0n's Avatar
i run between 35-40...usually closer to 40 on the old generation of azenis.
Old Nov 2, 2005 | 05:30 PM
get RIGHT's Avatar
Default Re: (visi0n)
At the AutoX this last Sunday on my 615s. I started at 38psi, it too seemed a little to "tail happy" and kinda squishy. So I upped to 50psi all the way round and it felt MUCH better. I kept it there and my times improved by 2secs. Although I don't like them much higher than 40psi on the street.
BTW; MAX PSI is 50 according to the sidewall.
danteisme
Sep 8, 2005 09:32 PM
onlyneed4
Mar 6, 2005 12:03 PM
RacerZook
Dec 30, 2004 02:21 PM
Andrew 825SM
15
Oct 12, 2004 03:10 PM
gribbs
15
Nov 5, 2003 01:41 AM
