routine timing belt change with 90k. replace cam seal and crankshaft oil seal???
yep i would since u already have everything out of the way
we always recommend at the honda dealership i work at
The cam plug is a maybe if it's weeping oil.
The front oil seal is a bit difficult to do without removing the oil pump. Outside diameter seals against the oil pump housing and inner diameter seals against the crank. Really nothing there to pull on to remove the oil seal. I say leave it if it's not leaking.
ya.. thats what i'm saying. I'm doing it for a friend, and i dont have the right driver to seat the oil seal perfectly. I would hate to have the seal have nothing wrong with it, install a new one and have it leak.
i think it is well worth it, wouldnt want your blt to go out and mess up your whole motor think of it as a $550 investment also get a valve adjustment
