How do I clean the coolant out of the oil?
Old Jun 6, 2005 | 05:40 PM
_Cyclone_'s Avatar
Default How do I clean the coolant out of the oil?
I just bought an Si with a blown headgasket... it's bad... it spits unburned coolant out the tailpipe. It looks like it's mixed with the oil a little too, how can I clean it out? Should I just drain and refill the oil a couple of times? Should I use an oil additive detergent?
EDIT: After I change the headgasket...
Modified by CycloneBlue_1.6EL at 10:14 PM 6/6/2005
Old Jun 6, 2005 | 05:44 PM
nsxmatt's Avatar
Default Re: How do I clean the coolant out of the oil? (CycloneBlue_1.6EL)
Um, yeah. Oil is cheap, just drain and fill it.
Old Jun 6, 2005 | 05:53 PM
sohcvtec1995's Avatar
fix the head gasket? then add new fluids. and your done.
Old Jun 6, 2005 | 05:58 PM
mrlegoman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">Should I use an oil additive detergent?</TD></TR></TABLE>NEVER!
Fix head gasket, change out your oil, your good.
Old Jun 6, 2005 | 06:10 PM
_Cyclone_'s Avatar
Default Re: How do I clean the coolant out of the oil? (mrlegoman)
I meant after I changed the head gasket. Should I change the oil a couple of times when I'm done to get all the crap out?
Old Jun 6, 2005 | 06:25 PM
BoostedCivic85's Avatar
Change gasket, pour cheap walmart oil first with the passenger side of the car lifted and remove drain plug.
chatman_55
May 20, 2009 01:16 PM
Fat Chick Magnet
Jan 1, 2008 11:59 AM
vtec.dc2
Aug 15, 2003 06:33 PM
G3gsr
May 20, 2003 06:17 PM
