How do I clean the coolant out of the oil?
I just bought an Si with a blown headgasket... it's bad... it spits unburned coolant out the tailpipe. It looks like it's mixed with the oil a little too, how can I clean it out? Should I just drain and refill the oil a couple of times? Should I use an oil additive detergent?
EDIT: After I change the headgasket...
Modified by CycloneBlue_1.6EL at 10:14 PM 6/6/2005
Re: How do I clean the coolant out of the oil? (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">Should I use an oil additive detergent?</TD></TR></TABLE>NEVER!
Fix head gasket, change out your oil, your good.
Re: How do I clean the coolant out of the oil? (mrlegoman)
I meant after I changed the head gasket. Should I change the oil a couple of times when I'm done to get all the crap out?
Change gasket, pour cheap walmart oil first with the passenger side of the car lifted and remove drain plug.
