Anyone ever fab'b mounts to fit b18a1 into 94 civic??
Iam lookinf for anyone who has fabricated motor mounts to fit a b18a1 going into a 94 civic.. anyone please let me know what mounts you used
well, with a cable tranny, it's different. hasport and hcp both make those mounts
as for a b18a1 with a newer hydro tranny, You'll need:
rear L bracket from 94+ integra
94+ linkages
front tranny mount from 94+ integra
a/c bracket from 94+ integra
you can reuse your stock civic side mounts on top of the tranny and and on the timing belt mount
94+ linkages
Okay, just to clarify.
b18 w/hydro tranny into EG:
94+ linkages
timing belt mount and upper tranny mount - stock EG mounts
So this is all that is needed, the engine is now properly mounted?
Now the timing belt mount- its a two piece mount, do you need the B18 bracket that bolts to the block or does that not matter?
Not sure if this was common knowledge for EG owners
but I'm gonna remember this for later.
94+ linkages
you can fabricate the tranny top mount after the driver's side and rear are mounted. Then you can fab up a clutch actuator.
use the b18a bracket on timiong belt and civic stamped rubber mount
damnbump
Jul 28, 2006 03:49 AM
seeeya04
Jun 7, 2005 06:24 AM
boosted_dc2
Nov 29, 2004 09:48 PM
