No start car
Old Jun 6, 2005 | 05:19 PM
gutted-dx's Avatar
Default No start car
I was driving down the road and all the sudden my car dies and i coast to a stop. I tried starting it and it wouldn't start, i couldn't hear the fuel pump come, so i thought it was the main relay. pulled the main relay and tested it and it worked fine. We sprayed starter fluid in it and it tryed to but i'm pretty sure its the fuel pump, but the ecu wasn't blinking the first blink when you turn the key on. . Don't want to have to put a fuel pump in when i doesn't need it
Help
Old Jun 6, 2005 | 05:41 PM
veggiemaster's Avatar
Default Re: No start car (gutted-dx)
Check your timing belt. I had the same thing happen to me and my timing belt snapped.
Old Jun 7, 2005 | 02:09 PM
gutted-dx's Avatar
It's not the timing belt, i'm not getting power to the pump or the ecu
Old Jun 7, 2005 | 02:21 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (gutted-dx)
Does the "check engine" light stay on when trying to start?
If so check this fuse:
Old Jun 7, 2005 | 02:33 PM
Agent STFU's Avatar
Default Re: (88DXCRX)
is it throwing a code? If so, let us know what it is.
Old Jun 7, 2005 | 03:28 PM
vegaskurt's Avatar
Default Re: (Syzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syzle &raquo;</TD></TR><TR><TD CLASS="quote">is it throwing a code? If so, let us know what it is.</TD></TR></TABLE>
No power to the ECU? Start at the fuse box under the hood and go from there.
Old Jun 10, 2005 | 04:35 PM
gutted-dx's Avatar
The ecu starts to get hot when you leave the car on
Old Jun 16, 2005 | 07:10 AM
gutted-dx's Avatar
ttt anyone have a clue
Old Jun 16, 2005 | 07:25 AM
2kTeg's Avatar
pull your cap off and see if your coil is burnt
Old Jun 16, 2005 | 08:26 AM
ITRnorway's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">Does the "check engine" light stay on when trying to start?
would i get sparks on all my wires if that fuse is fried?
Old Jun 16, 2005 | 06:21 PM
gutted-dx's Avatar
I'll try that but why would a burnt coil stop the fuel pump from kicking on
Modified by gutted-dx at 8:51 AM 6/17/2005
Old Jun 17, 2005 | 07:51 AM
gutted-dx's Avatar
ttt
Old Jun 17, 2005 | 07:59 AM
CRseXy's Avatar
ECU dead?
Old Jun 17, 2005 | 08:31 AM
trrbl1bmx's Avatar
If your getting spark at your spark plugs then it is not your coil. It's most likley an electrical problem, so check all your fuses. And if you still havent gotten anywhere, come ask us.
Old Jun 17, 2005 | 02:31 PM
gutted-dx's Avatar
Checked all the fuses and checked the ecu and all is good, also the main relay is.Is there a ignition relay
Old Jun 17, 2005 | 03:18 PM
gutted-dx's Avatar
Is the alternator solenoid vavle the same thing or 2 different thing, because i was looking at the fuses and who ever had it before me had a 15amp fuse instead of a 10 could that have fried the alternator and not let the ecu and fuel pump get power
Old Jun 17, 2005 | 04:42 PM
CRseXy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx &raquo;</TD></TR><TR><TD CLASS="quote">Is the alternator solenoid vavle the same thing or 2 different thing, because i was looking at the fuses and who ever had it before me had a 15amp fuse instead of a 10 could that have fried the alternator and not let the ecu and fuel pump get power</TD></TR></TABLE>
Possible, but WHAT caused it to blow that fuse, or suposed to blow a 10amp. They just dont go for no reason, but Replace that fuse with the right amprage, ASAP.
Old Jun 17, 2005 | 04:59 PM
gutted-dx's Avatar
I already changed the fuse, could it have shorted the alternator becuase some guy had the same problem and it was that fuse
Old Jun 18, 2005 | 11:19 AM
gutted-dx's Avatar
TTT
Old Jun 18, 2005 | 11:52 AM
Skinflute22's Avatar
there is a starter relay...its located under the dash i believe there is a red/black wire and a blue/black wire and 2 black ones maybe its just a little box over on the far driver side pretty close to the door...that might have gone out
Old Jun 18, 2005 | 12:03 PM
gutted-dx's Avatar
I'll pull that and try and check it
Yama801
Jan 4, 2018 03:38 PM
Boomboy14
20
Mar 26, 2010 05:33 PM
CHONCH2
14
Jan 21, 2010 10:26 AM
707the89fu
Feb 18, 2007 10:22 AM
ibanez4string
Nov 16, 2004 04:58 PM
