How to disengage clutch safey in integra?
Old Jun 6, 2005 | 04:31 PM
brickonwheels's Avatar
Default How to disengage clutch safey in integra?
Over the past two days, i have been wiring in my remote start system into my 96 integra and have everything hooked up. I can remote start my car if i push in the clutch but can not without. So i need to know how i might be able to disengage the clutch safety switch at the top of the clutch pedal, if any of you can help, that would be great.
And i know all of you would worry about the legality issues of the remote start, but i am well aware and have decided to go ahead with it regardless. But thank you for your concerns
Old Jun 6, 2005 | 04:51 PM
Auex's Avatar
Default Re: How to disengage clutch safey in integra? (brickonwheels)
Wire a relay to make connection between the two wires at the clutch when the remote start engages.
Old Jun 6, 2005 | 05:04 PM
Can i just wire the two together?
Old Jun 6, 2005 | 06:07 PM
Auex's Avatar
Default Re: (brickonwheels)
Yes, but a relay would be the correct way.
Old Jun 9, 2005 | 01:33 PM
so simple's Avatar
clutch on integra just needs a ground signal, i used a ground out on a remote start i did
EGed up from the seat up
Apr 6, 2011 06:33 PM
D16SiHatch
Audio / Security / Video
Mar 31, 2009 06:12 AM
brickonwheels
Jun 7, 2005 08:44 AM
96BlackHB
Sep 20, 2002 11:53 AM
TurBoXBirD16
Mar 5, 2002 09:10 AM
